Does not drain properly . I think the pump is shot/blocked
    Genius:
  • 1,073 Answers
Take the hoses off of the pump and look for obstruction
Posted on Apr 25, 2008
Samsung dishwasher starts and after while stops with three lights cycles on (heavy , normal and quick)
I think that light combination means "Drain error". Most comonnly caused by something hard getting down into the drain pump, blocking or partially blocking the drain pump impeller or the check valve inside the drain hose right next to the drain pump.
Feb 24, 2015 | Samsung Dishwashers
Washing machine did not drain, other functions work properly
Check drain hose first. If ok, possibly belt is shot or pump loosened up to cause slippage. Depending upon design, front of washer removes to view pump. Visually check first and then start washer in drain cycle to observe if pump turns. Belt or pump is simple fix.
May 19, 2014 | Dryers
Trying to diagnose a problem and have back panel off. Belt was off AND I think the cause is that the drum pulley and inner drum will not spin without a lot of pressure. I figure the motor (which appea
Either something is caught between inner & outer bowl or drum bearings need replacing. Also check outlet hose going to pump sometimes object caught there causing the bowl to be tight to turn.
Dec 11, 2013 | Maytag MAH2400A Compact Front Load Washer
Dishwasher will not drain I think it:s the pump
It will help if you provide the make and model of dishwasher. There can be several reasons for dishwasher not draining. The most common is blocked filters or drain hose. Also ensure the kitchen side of drain is clear. If pump is running but making grinding sounds then something is blocking the drain pump. If you do not hear pump running sound then the dishwasher may not even be getting to the drain cycle for other reasons.
Apr 19, 2013 | Dishwashers
08 LG washer not draining and reads 03. What's the problem?
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Nov 03, 2012 | Washing Machines
Won't drain properlt and F02 error
Junk in the pump, clean out the pump filter and test it. Otherwise the pump impeller may be shot.
Dec 30, 2009 | Maytag Washing Machines
Washer will not drain. I can hear the pump running, have checked the filter and the hose for blockage...still will not drain.
To make sure the pump is working properly, open the filter. If you have water left in the machine, this will gush out once you twist open the filter, so be prepaired for that.
Most LG font loaders have a thin drain tube next to the filter cap, you can drain the water out slowly into a bucket before hand.
Once you have taken the filter out, Start the machine on the "Drain" or "Spin Cycle. Look into the filter cavity with a torch and see if the pump propelors are spinning properly and that they havent brocken off from the motor shaft.
Please dont stick your fingers in there whilst it is running. If the pump seems to be turning O.K. then the only other thing which I can think of is a coin which has blocked off or closed off one of the hoses.
I have seen cases where the diameter of a coin is exactly the same as the drain hose, and once lodged in there, it makes a perfet wall and blocks water flow.
You will need to check all the hoses individually by taking them off. First remove the hose leading out from under the tank going to the water pump. Then the drain hose going from the pump to your sink or drain. Sometimes it may be easier to lay the machine on its back and access the hose from underneath the machine.
Take note of how the hoses are joined on so that you can put them back on as they were.
Good luck
Ash
Oct 31, 2009 | LG WM1812C Front Load Washer
Too many suds
Most probably a blocked or partially blocked pump.
Sep 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
