Question about Microsoft Windows XP Home Edition
Windows XP The Add or Remove feature in Control Panel of Windows XP stopped working. Everything else in Control Panel works fine. Can you help? Dan Gomez dbgomez@stic.net
    Novelist:
  • 119 Answers
Dear Dango,
Please Go to Start - Run and paste the following command then press Enter.
%SYSTEMROOT%\SYSTEM32\appwiz.cpl
Check again now ..do the add/remove programs open?
Regards
EngineerGR
Posted on Apr 25, 2008
  • T.M.
    T.M. Apr 25, 2008
    IT Tech Rep ...? Are you confused ? :)
  • 323 Answers
This seems to occur mainly with Power Macintosh G3 Desktop computers. The cartridge is not ejected far enough from the front of the Zip drive's plastic bezel, and users tend to push the cartridge back into the drive slightly making it almost impossible to remove. This is most likely to occur if you try to remove the cartridge by grasping the top and bottom edges at the same time.
Testing has shown that if you attempt to remove the disk by placing your finger on its bottom edge and pushing up slightly while pulling out, the disk can be removed almost every time.
  • Dalynn Turner Apr 25, 2008
    Sorry, disregard the other comment.
    Here is what you want.
    start/run and type
    regsvr32 appwiz.cpl
    MAC question was removed, so somehow I posted to this question instead. Weird. Regarding Iomega Drive issue. FQDN probably required to fix add/remove programs issue though. Good call.
Why has my internet explorer has stopped working
Windows 8.1 upgrade or virus most likely. Start up in safe mode go to control panel add remove program's windows features. Untick ie then reticle restart and should be fine.
Jul 09, 2014 | Computers & Internet
Cant find the add/remove programs in control panel, im using windows 7.. i want to uninstall IE9 and install IE8
Click the start orb in lower left corner of desktop and type "prog" without the quotes. At or near the top of the list of results that comes up will be "Programs and Features". This is what the add/remove control panel section is called in windows 7. Just click that and uninstalling works the same as it did in xp.
Sep 26, 2011 | Microsoft Internet Explorer 8
Fax driver missing
Microsoft Office 2010 has a feature that lets you send Outlook, Word, Excel, and PowerPoint files as Internet faxes. This feature relies on having the Windows Fax Printer Driver or Fax Services installed on the computer to send the faxes. The Windows Fax feature is not enabled by default for all editions of Windows. If your edition of Windows includes the driver or service, you must install it before you can send Internet faxes.
Which operating system are you using? Windows 7
  1. In Control Panel, click Programs, and then click Programs and Features.
Note In Classic view, double-click Programs and Features.
  1. Click Turn Windows features on or off.
  2. In the Windows Features dialog box, under Print and Document Services, select the Windows Fax and Scan check box.
  3. Click OK.
za010077668.gif Top of Page
Windows Vista The Windows Fax Printer Driver is included in the following editions of Windows Vista: Business, Enterprise, and Ultimate.
  2. In the Windows Features dialog box, select the Windows Fax and Scan check box.
  3. Click OK.
Windows XP
  1. In Control Panel, click Add or Remove Programs, and then click Add/Remove Windows Component.
Note In Classic view, double-click Add or Remove Programs.
  1. In the Windows Component Wizard, select the Fax Services check box.
  2. Click Next.
Windows Server 2008 To create a fax server, you must install the Fax Server role. This installs the Fax Server role page, Fax Service Manager, Windows Fax and Scan (with faxing capabilities only), the Fax service, and the Fax printer.
  1. In Control Panel, under Programs, click Turn Windows features on or off.
  2. Right-click Roles, and then click Add Roles.
  3. In the Add Roles Wizard, under Select Server Roles, click Fax Server role.
Note If Print Services are not installed, you are prompted to install it.
  1. Click the users or groups that you want to send faxes.
  2. Click who you want to have access to the fax server inbox.
  3. Click Install.
Windows Server 2003 The Fax Service is included in all editions of Windows Server 2003 except the Web edition.
  1. In Control Panel, click Add/Remove Programs.
  2. In the Add/Remove Programs dialog box, click Add or Remove Windows Components.
  3. In the Windows Component Wizard, select the Fax Services check box, and then click Next.
  4. If you want to share the fax printer so that everybody in the network can send and receive faxes, click Yes.
  5. Click Finish.
Click here for fax driver
Jul 26, 2011 | Office Equipment & Supplies
MY DELL 948 WILL NOT SEND A FAX
there is a generic Fax program in windows XP. If your using the vista home basic or home edition, it does not have these function unless you install an actual fax program. If not you can install it by
for XP -go to the start -control panel -go to the windows add remove programs -add remove windows components and choose the Fax services
-Vista -go to start -control panel -programs and features -add remove windows components and choose the Fax services
hope this helps
Jun 23, 2011 | Computers & Internet
The we- care reminder keeps popping up how do i make it stop?
Open your Start menu and choose Control Panel.
In Windows XP: choose Add/Remove Programs.
In Vista: choose Programs/Features.
In Windows 7: Choose Uninstall a program.
Find the We-Care Reminder (may be ASPCA Reminder by We-Care.com).
Choose Remove (Windows XP), or right click and select uninstall (Vista and Win 7).
If you have any issues, contact We-Care.com support at (iesupport at we-care dott com).
Nov 08, 2010 | HP Computers & Internet
How do i download outlookexpress free
Outlook Express comes with your operating system. Goto control panel -> add / remove programs -> add / remove windows components. Check the Outlook Express box. If your OS files are not saved on your hard drive, you will need your original CD.
HTH
Dan
Aug 09, 2010 | Microsoft Windows XP Home Edition
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Aug 12, 2009 | Computers & Internet
Computer shows printer installed but will not send image to printer to be printed
try to uninstall and reinstall the printer softwate and drivers, using the control panel to remove("Add and Remove Programs" in Win XP), and reinstall using the Disk or downloaded file from Manufacturers website which you can get the most Updated software and Drivers from the Mfgr. Website (Usually software\Drivers, or Support\Downloads) enter model and OS (ex Win XP or Win Vista, or Windows 2008),
I Hope this helps, please give a good rating if it does, Gomez
Jul 02, 2009 | Office Equipment & Supplies
How do i reinstall world of warcarft
Just put your cds in and it should autorun. Follow the steps.
It takes forever. So be patient.
:D
-Captain Jake
Feb 11, 2009 | Blizzard Entertainment World of Warcraft...
No Has Been Able To Solve This Office 2007 Pro Problem, Can You?
The problem is the feature you tried istalling might have corrupted the OS. What you can try doing is create new user account first , restart your computer into the new user computer and then try installing. If the same still doesnot work , then my friend the only solution would be to reinstall windows xp and then put office 2007.
Thanks
proton
Dec 13, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
