Question about Sony Playstation 3 (PS3) Console
Hello, i have a ps3 that produces no output to the tv, i have tried other tv's. i have reset it several times and got a blank screen and a screen that said i must connect a usb to the controller and push the ps button but the controller never connected.
My website has ALL THE POSSIBLE SOLUTIONS for ps3 blackscreens. http://ps3blackscreen.blogspot.com
Posted on Aug 05, 2010
I by mistake from the menu I pressed the hdmi botton. It went blank and I can't get a picture. What can I do?
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Sep 22, 2014 | Video Game Consoles & Games
Hdmi ports not working
reset your playstation 3 video setting
Reset Video Output
Jul 21, 2013 | Sharp AQUOS LC-40LE830U 40" LCD LED HDTV
I hooked my ps3 to the hdmi connection in the back,neither the system or the tv recognize the connection, i get a blank screen.I know the hdmi cable is good because I tested it.Any suggestions?
It could be that the PS3 is outputting a higher resolution than your TV can handle. Here is an excerpt from the PS3 manual:
If the video output settings do not match those required for the TV in use, the screen may go blank when the resolution is changed. The screen should, however, automatically go back to its original resolution after a while. If the screen remains blank for more than 30 seconds, turn off the system. Then touch the power button on the system front for at least five seconds to turn the system on again. The video output settings will automatically be reset to the standard resolution.
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Mar 09, 2011 | Televison & Video
WHEN PLAYSTATION3 IS SWITCHED ON TV STATES NO INPUT SIGNAL AND SCREEN REMAINS BLANK
Hello,with the ps3 off ,hold down the power button till you here the second beep than release it ,this will reset your video output within about 7 seconds.
Jan 15, 2011 | Sony PlayStation 3 40GB System
My kids PS3 comes on and then when you push play the light turns green and you hear it start up for a couple of seconds and then it goes off.
R - Restore: Restore default settings E - Environment: Change your environment, remove from media cabinet, try different media, try different equipment (TV, router, hotspot, etc.). P - Power Cycle: Power cycle by unplugging your networking equipment from wall for 2 minutes to reset. A - Access this Knowledge Center for useful articles to resolve issues. I - Install the latest System Software Update. R - Resolved: In most cases these steps can resolve your issue.
Adjust the video input on the TV to match the input connector that is being used to connect to the PS3™ system. Check that the cable is securely inserted. Try disconnecting the cable from the PS3™ system or TV and then reconnecting it. There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3™ system. If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system’s power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution. If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system’s video output settings, and then select all the resolutions that are supported by the TV.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
Plugged ps3 into tv but nothing is happening. av1 and 2 are not getting anything up on the screen?
1 I take it that you are using the right connecting cables which are compatible with PS3 system. 2 Check the cables are securely inserted. Try disconnecting the cable from PS3 system and TV and reconnecting them. 3 If the video output settings on the system do not match with those of the cable or TV there is no picture. In this case turn off the system. With only the system and TV connected touch the system's power button for more than 5 secs to turn the system on. The video output settings will automatically be reset to the standard resolutions. 4 If the resolution of the video is not supported by the TV the screen will be blank. Then go to system's output settings on the screen, select "Custom" and then select all the resolutions supported by the TV
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
When my ps3 is hooked up to my proscan lcd 37LC30S60 via hdmi it has a blank screen that says no support
Have you tried changing the settings on the ps3? If you go into the display settings adjust them Also if you want to change the ps3 to the default
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn the system off.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps.
    Thank you,
    Lee
    Dec 12, 2009 | Proscan 37LC30S60 TV
    No video/audio output
    problem with the main board then. You tried different cables, reset the ps3 and also tried different tv's to be sure it wasn't a TV issue.
    You did everything I would have done. Call sony if you decide to get it repaired by them. I think they charge $150 from the last time I checked.
    Sep 04, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 as no video or sound i bought 3 wires for the tv and no color or soud sows we even used a ps2 cable
    Excerpt from the PlayStation 3 Manual:
    There is no picture on the TV screen.
    *Check that the input mode of the TV is appropriate for the connector in use on the system.
    *There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3 system.
    *If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
    *If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
    Jul 29, 2009 | Sony Playstation 3 (PS3) Console
    PS3 Screen is blank
    No i think your ps3 froze or your settings r 4 hmdi and not snail cables next time reset your tv sometimes the hdmi freezes
    Jan 27, 2009 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    32 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
