Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Recoil rope replacement and spring tension for Poulan Pro PP333
Rope pulled out. How to replace rope ? ( trimmer has regular spring for pullet plus another smaller pulley in center.
4 Suggested Answers
  • 279 Answers
SOURCE: broken rop on weedeater gas trimmer
There is a spring under the starter spool, the one with the rope on it, leave the spring ALONE, Just take the spool and replace the rope as it is. You take the spool off, put the new rope on the spool, place the spool onto the spring and by holding one end of the rope straight up in one of the slots on the spool, go as many times as you can. When you have it as tight as it can go, hold your thumb down on the spool. Insert the rope through the hole available, grab the rope on the other side of the hole, (outside the casing). Hold the rope and S-L-O-W-L-Y allow the rope to retract. If it finishes before the rope runs out, pull on the rope and install the handle. If it tries to go beyond, hold the rope and install the handle there. Hope you have luck. Remember, leave the spring alone...Lee
Posted on Aug 03, 2009
  • 77 Answers
SOURCE: I have a Poulan Pro link trimmer PPB225E. The rope
It sounds like when it was assymbled that the cord wasnt routed through the holes of the plastic disk right to avoid it being pulled out. If you attempt to fix it yourself its no easy task,the entire casing needs unbolted and seperated. You need to make sure you DONT pull the recoil bands out,and there is a proper procedure of the cord routing and tying.This is a pretty advance repaire for a novice.
Posted on Aug 09, 2009
rycgl
  • 1545 Answers
SOURCE: how do you get the starter rope to rewind after
The starter rope normally rewinds automatically when the recoil unit is functioning properly. If the pull rope has stayed out, disassembly will be required. Here are instructions for that problem. The recoil spring can break and is replaceable, but the nylon hub in the starter recoil unit is usually the problem or the rope has broken and jammed inside.
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Here are more details for servicing the starter/recoil unit....With the starter/recoil unit OFF the machine, with no rope in it, and no tension on it.....grasp the little nylon hub and turn it (clockwise is I recall) round and round 6-7 times until you feel the recoil spring get nice and tight...DO NOT LET GO OF IT!...hold it in place and then JAM the starter/recoil unit in place (still tight) inside it's housing by either clamping it with a tool like vise grips or by sticking a screwdriver thru it and thru the vents in the cover. If you have ANOTHER person to help you...one of you hold it in place....and make sure it is lined up to where you can NOW insert the new lenth of pull rope. Always use new rope....Feed the end thru the hole in the recoil unit and tie it off, by wrapping it around itself outside the nylon hub and then screw the little self-tapping set screw back in holding the rope down. OK...then feed the opposite end into the hole in the front engine cover and attatch the T pull handle....Now mind you, you are still jammming or holding the recoil in place against the spring!...Now, unclamp it or unjam it and slowly let the recoil pull the NEW rope you just installed back onto the pulley. Make sure it is fastened well on top of the pulley around the nylon hub and also fastened well onto the T pull handle. That is it. Then reconnect your wires, put your throttle cable back thru the engine cover and reinstall the Torx screws in the cover...and you are doneervicing the recoil unitl
Posted on Jun 05, 2011
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
How do I replace the pull cord to my Poulan 446T PRO. It's a combination of a pole chain saw (8 inch) and a trimmer.
You will take the recoil assembly off the saw. You shoud see where the knot broke off the cord in the pulley. Put the cord through the case and the small hole in the pulley and tie a new knot. Count the number of turns it takes to take up the rope. There should be a small notch in the edge of the pulley you place the rope in to wind up the spring and not take up the rope.Add one or two turns more than you counted so the rope is coiled up snug then pull out the rope from the notch and let the spring retract it.
Aug 02, 2013 | Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
How do I replace the pull rope on my bl100 trimmer? I know how to install it just not how to get it to rewind.
You are going to need to "preload" the spring in your recoil/starter unit BEFORE you install the pull rope. Turn in in the direction where you feel it becoming tighter. Turn it about 5-7 revolutions. Don't get carried away and make it REAL tight as you will break the spring steel recoil spring. After you have it set, jam it or hold it with vise grips or a screwdriver or with your hands and have someone install the pull rope. Make sure the handle is installed on the end of the pull rope before you begin because when you let the recoil pull your new rope in the handle will stop it. There should be a little bit of tension left on the pull rope once it is drawn in all the way.
Oct 31, 2010 | Garden
How to repair a poulan pp 136 trimmer? The rope to start won't rewind.
Most likely you have a broken return spring.whitch will involve removing the blower cover and putting in a new spring,and then reloading the tensionon it.there is trick to that but its hard to explain....you have to tuirn the rope holder the oppisite direction you want it to pull the rope in ,then you feed in the rope while holding the spring loaded then tie the string in and let go...Normally 4-5 rounds will do for a good recoil..Hope it helps
Aug 27, 2010 | Poulan Garden
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
I have a Poulan Pro Blower PPB2000LE rope came loose so I took it a part and now I don?t know how can I rewind the rope with the spring, should I use clock direction or the other direction.
It is not a question of clockwie or not, it depends on the direction of rotation of the engine, they are not all the same.
*wind the rope/spring in the direction that the rope would pull the rope rotor.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 16, 2009 | Poulan Featherlite Gas Blower, with Low...
The rope doesn't pull smoothly. I removed the
Before installing fasteners for the recoil to the housing, pull the rope a small amount 2-4". With a small pressure from your other hand, at the same time push gently down on the recoil housing. This should partially rotate the flywheel and align the pawls to the rope rotor. Repeat this proceedure until you feel the pawls drop into place.
You may want to review the proceedure for installing a rope to complete your repair.
Nov 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Broken rop on weedeater gas trimmer
Jul 23, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Wont coil back into its housing, so trimmer wont start. Has compression though
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
May 19, 2009 | Poulan Pro 25hht 25cc 22" Gas Hedge...
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
188 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
