Question about Boss AUDIO SYSTEMS D8002 Car Audio Amplifier
What size blade fuse would I need for my D800.2 Boss amplifier? I took it to a shop to work on my music system ,and for some reason they threw away the fuse. I don't remember what size was in the single fuse slot before.
  • 4 Answers
You need a 30 amp fuse according to Boss Audio's owners manual.
http://www.bossaudio.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=564&nav=0,2
Posted on Aug 02, 2010
After 7 yrs of use, it just stopped working
I agree that It could be one of the other reasons listed here.....
But, I had the same problem with a 1,000 watt Kenwood amplifier and it worked like a boss for the whole two years that I had it and then one day the box that I had my subs in somehow came apart and after I changed out boxes the amp quit working. It came on but it wouldn't work anymore except for when I turned it a certain way or sat it against something.. Anyway it ended up being a loose female port plug on the inside where the auxilary cables plug up.
Hope it helps.
May 11, 2013 | Clarion APA4320 Car Audio Amplifier
800 watt mono block sony xplod amp blowing my dual coil 1500 watt subs
if the wiring to the sub is correct, then you have something wrong with the amp itself... something is power surging to the subs which is causing them to blow
Aug 25, 2012 | Car Audio & Video
What size fuses do i need for the 3 slots and im blowing the power fuse its all hooked up right
  • A Metrik MAX-1404 Amp requires 3 20 Amp Maxi Blade Fuses yellow in color.
Regards, Tony
May 23, 2011 | Metrik Amplifiers MAX-1404 Car Audio...
I have a boss s120.5a 12" sub with 5 channel 3000
Check the power pack and the fuse to make sure the are working but if the are not okay then take the car audio amplifier to audio mechanic.
Jan 22, 2011 | Boss gt580 - GT580 1000W 2 Channel MOSFET...
Blown fuse
Continued replacement of fuses without fixing the reason for them blowing MAY be doing additional damage to components in the unit.
It needs to go to a repair shop. It is likely there is damage in the power supply section or that of the power amplifier section.
Feb 28, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Boss noise reduction pedal stopped working for no reason at all. worked fine the day before, went to use today no power at all. it is run from an adaptor so its not the battery, any clue?
The power jack on MANY of the pedals are weak and a yank sideways can damage the jack or the board it is mounted on.
ANOOTHER problem is using an adapter with the wrong size plug. SOME plugs have a larger diameter hole and will work intermittenly.
Oct 05, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Channels Not Playing
i had afriend who is atechnician. his boss amplifier stopped working on one channel,so what he did is openened the amp,tested the mosfet transistors and it showed signs of failure.then he went shopping for same type of mosfet transistors and with no luck in buying the right type, he put the amp away for acouple of weeks. then one day he hooked it up and strangely it worked again. he told me that while it was hooked up itwent into protection mode and for some reason it worked later. so i would not open it because of static discharge i would disconnect the amp for maybe acouple of weeks then hook it back up.... its worth a try & good luck
Nov 10, 2006 | Boss C350 Car Audio Amplifier
Boss AUDIO SYSTEMS D8002 Car Audio Amplifier Logo
160 people viewed this question
Top Boss Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
