Question about Garden
The gas lines are corroded and broke. I bought a repair kit for a 25cc, 26cc and 30cc thinking it would work. I was wrong. where can i find a gas line repair kit for the 31cc?
  • 1,498 Answers
Hi Rob,
Not knowing your location, I can only suggest some of the more popular chain store's.
Home Depot - Garden Center
Lowes - Garden Center
Walmart - Auto, Garden,
Sears - Tools, Garden Tools, Parts depts (online)
Hope this point you where you need to be.
Be regards
Mike
Posted on Aug 02, 2010
Broke small black connector between fuel line to side of carburetor. Flat bottomed funnel shape fits in to side of carb. Has filter inside. I believe it feeds the primer.
That is a fuel tank vent kit. Most models have a vent in the fuel cap but that model uses a separate line with a Duck bill vent (usually a green rubber inside that piece in picture). Part number for that is 574859301 . Your blower should run ok with out it but could leak fuel. If you are going to order any parts for your blower do so using Model # PPBP30 Your parts will be cheaper. That particular model has exchanged hands between MTD/Mcculloch/Bolens and Husqvarna/Poulan over the years. The parts are cheaper when you use the Husqvarna/Poulan model # PPBP30. Only noticeable difference will be a yellow starter housing if you buy a starter assembly.
Dec 17, 2015 | McCulloch ASB3206 - Blowers - 30cc Gas...
Cutter spins freely
The driveshaft is broke in the tube or the head drive is broken or srtipped out. Take head off and pull out the cable. It just slides out.
Apr 16, 2014 | Craftsman 25cc Gas Line Trimmer
How do I replace the fuel bulb?
Homelite and Ryobi appear to be made by the same manufacturer. Home Depot now carries a "Fuel System Tune-Up Kit, AC04122," that includes 2 replacement fuel lines and a replacement Primer Bulb for 25cc, 30cc, and 26cc 2-cycle engines. Cost is $7 +.
Aug 27, 2012 | Homelite Mighty Lite Blowervac
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
I have a 25cc weedeater 358791030.I need a gasket repair kit for inside of carb. Sears told me they do not have repair kits for inside of carb only a gasket for carb mount.Any suggestions........Thank you.
Look on the body of your carburetor. There should be a set or two of numbers molded into it. Take these #s (they're the model # of your carburetor) and enter them into the Cross-Reference Page on PartsBuggy.com's website. If there is a kit available for the carburetor, you'll find it there.
Jul 12, 2011 | Craftsman 25cc Gas Line Trimmer
Type of trimmer: Poulan Pro PP125 17-Inch 25cc 2-Cycle Gas-Powered Straight-Shaft String Have not used the trimmer in a couple years due to broken fuel line. replaced the lines today. The primer bulb...
Try cleaning your carb and even buying a rebuild kit. I do not think you have a blockage. Does it even try to start? Cleaning the carb will give you a chance to get rid of any debris or old gummed up fuel and oil that may be in there, give it a try. Good Luck...
Jun 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
I have a craftsman gas weekwacker model 356.791520 is there any diagram of the fuel lines. I think I repaired them wrong.
Looks like you've possibly referenced the wrong model # for your trimmer. There is a diagram available for model 358.791520, but not a 356.791520. You can find it here - http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358791520/0247/1503820?searchedModel=791520&blt=11.
Once you get the Sears numbers for parts you need, you can find replacements for them at HyperParts.com's cross-referencing page here.
May 19, 2010 | Craftsman 25cc Gas Line Trimmer
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
