Question about Fellowes Office Equipment & Supplies
DS12Cs gears Where can I find replacement gears for a Fellowes DS-12Cs shredder?
4 Suggested Answers
dlundmark
  • 797 Answers
SOURCE: Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Posted on Jul 26, 2008
SOURCE: Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
Posted on Aug 07, 2008
  • 610 Answers
SOURCE: Need replacement main gear for fellowes shredder
call fellows at 1-800-955-0959
Posted on Nov 18, 2009
Main Gear for DS-12CS Shredder
Fixya is unable to identify parts sources.
Jan 23, 2018 | Miscellaneous
Before I recycle the metal from my DS-1 Fellowes shredder (small driven gear stripped) does anyone need any other parts? Two larger gears are good. Norm
I'm desperately looking for the small nylon gear (see attached photo) of the DS-1.
As I live in Brussels, Belgium I'm also curious to know where you have found the gear outside US and at which price.
Thanks,
Dirk.
before-recycle-metal-from-ds-1-fellowes#solution-section-ew2ec1vog3kw5zx5dcajxfma-4-3.jpg
Jan 27, 2015 | Fellowes Office Equipment & Supplies
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
How do I take top off of Fellowes PS-12Cs to clear shredder
start up by removing the out the container out, then remove the screws that are under the shredder and the base. now remove the remove the top of the base and placed upside down and remove the (2) screws off the motor each located on the left and right side of the motor. and you will access to the gear of the machine and be able to cleaned.good luck. and let me know how it go.
May 23, 2014 | Fellowes SB85C Shredder
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Have Fellowes shredder model DS-12Cs, serial # 080317VB0373155, that is now dead. No power, no lights. There is a fuse on the circuit board labeled 3S6.3A 250v that appears to be bad. Can it be rep
Solder-in fuses (and thermal fuses) are fairly common and should be available from many outlets such as good constructor stores and the sort of outlets professional repairers use.
If a fuse can't be sourced there are a wide variety of conventional fuse holders available that could be grafted onto the circuit board.
Once replaced, if the fuse fails again, you can be certain there is a fault that must be traced and rectified before replacing again.
Nov 10, 2017 | Fellowes Office Equipment & Supplies
Gear for a DS 1 Fellowes shredder
heres a site that has alot of gears
also http://www.compax.com/shredders/parts.html
you may have to call or email them , as all parts are not always listed on the website
Oct 16, 2008 | Fellowes P400C-2 Shredder
Auto shut off
You may want to examine the unit carefully and remove the screws which hold the unit together, you will find these screws on the bottom. Either there may be scrap over the switch or sensor or the sensor or switch has been broken. Clean the unit as best you can. You may be able to find the problem from your examination.
Jul 26, 2008 | Fellowes P70CM Shredder
192 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
