Question about Savin 2545DP Black and White Copier
Replacing disk drive on Savin 2545 copier
I have a Savin 2545 that needs a new hard drive.
1. Can I just replace it with a blank identical Maxtor 541DX drive?
2. What format should be used to initialize it. (FAT32?)
3. Is there any software that needs to reside on the drive? If Y, where can I get it?
4 Can any Ultra ATA/100 hard drive be used?
checkitright
  • 1362 Answers
SOURCE: Savin 4090 error code
check this link, look under error codes
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Posted on Feb 18, 2008
Cogz
  • 1326 Answers
SOURCE: Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Posted on Jul 22, 2008
  • 990 Answers
SOURCE: Functional problem with the copier (Savin 2545) Service Code SC 546
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
Posted on May 29, 2009
savindude
  • 175 Answers
SOURCE: PRINTED PAGES ARE BLANK AFTER REPLACING PHOTOCONDUCTOR
The machine should automatically recognize the new PCU. Blank copies would lead me to think you have further problems, charge corona? transfer issues? If you try to make a copy and open the front door real fast when the paper should be at the transfer unit, is there an toner image showing on the drum? If yes, then you have charge but not getting transfer. This is a hard problem to troubleshoot without seeing machine. Anyway good luck, please rate this. Thanks ..... Wait... just had a thought. On the shaft, on the inside of the rear frame, that drives the drum there is a coupling that is spring loaded. Sometimes the shaft gets gunked up and coupling does not pop out not connecting to the PCU, which could cause blank copies and will still say replace pcu. You could add a couple of drops of oil to that shaft to loosen it up if that's the case.
Posted on Jul 01, 2009
Ickoajnc
  • 204 Answers
SOURCE: Savin 2545 throwing error code SC672.
Open the operation panel the cable which connects the controller and the operation cable might be not good attached or something like that.
The operation panel you might open by unscrewing the two screws on the front of the control panel and then pull the panel towards you.
Inside you will see some cables see if they are good connected or just disconnect them and connect them again.
If that not fix the problem than you have problem with the controller.
You might do the same procedure like with the panel.
Just remember to turn off the machine before you
pull out the controller.
The controller can be pulled out by unscrewing two screws on the left back side of the machine where you connect the machine with computer you cannot miss that part because the hole machine is with white plastic and that part of the machine is metal part.
Posted on Jul 15, 2009
How do I wipe the hard drive from a SAVIN 2545 Copier manufactured in 2002?
you can use aomei partition assistant, it is free and has the feature erase hard drive, you can see this tutorial: http://extend-partition.com/help/wipe-data.html
Jan 11, 2013 | Savin Office Equipment & Supplies
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
Mar 14, 2011 | Savin 2545DP Black and White Copier
I want to replacement of my 80 Gb hard disk but I unable to find S/N or P/N in your list My hard disk Model :SP0842N P/N:35201QSS900464 S/N : S0DWJ1BP108754 Please help me for replacemest of above...
You do NOT need to buy a new Samsung disk-drive.
You can buy a replacement from Western Digital, or from Seagate/Maxtor, or any other manufacturer.
Take your current Samsung disk-drive to the computer-store, so that they can sell you a new disk-drive with IDENTICAL data/power connectors (either Parallel-ATA or SATA).
Feb 01, 2011 | Samsung (MP0804H) 80 GB Hard Drive
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 internal hard drive not working think it might be the PCB Board not working.
It's possible that you're correct.
However, finding a Maxtor drive with an identical PCB is not going to be easy. Once you do, you can disconnect the "spinning" part of the disk-drive away from the PCB, and then swap PCB, and see if you can then QUICKLY(!) copy all 80GB to a "new" disk-drive.
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
Service code 990 savin 2545 copier
If changing the cylinder, developer and blade the problem is not solved, proves to resetear software pressing by more than 10 seconds the point (.) and the numeral (#) both simultaneously, until it is extinguished and it returned to ignite the machine, this resetea software. If the problem persists, then the problem can be in the hard disk, replaces hard Disk.
Si cambiando el cilindro, revelador y cuchilla no se soluciona el problema, prueba resetear el software presionando por más de 10 segundos el punto (.) y el numeral (#) los dos a la vez, hasta que se apague y vuelva a encender la máquina, esto resetea el software. Si persiste el problema, entonces el problema puede estar en el disco duro, reemplace el Disco duro.
Aug 03, 2009 | Ricoh Aficio 450 Copier
Jun 30, 2009 | Savin Office Equipment & Supplies
May 29, 2009 | Ricoh Aficio 450 Copier
Savin 2545DP Black and White Copier Logo
293 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
