I HAVE A CARRIER 48GS AIR NOT COLD ENOUGH TO COOL HOUSE
chillmaster
  • 104 Answers
SOURCE: air not blowing out forcefully
If you had a company out to do this, it sounds like they didn't check things very well. It is very possible that you have a leak that needs to be repaired. Also, it could be a problem with the indoor fan or a plugged air filter. The coil is probably freezing over with ice because it is too cold caused by one of these problems
Posted on Jun 12, 2008
manhandy
  • 146 Answers
SOURCE: My central air conditioner is not working
well how cool is cool check temp at one of the register should be around 54 degrees. if so you other problems
Posted on Jun 26, 2009
  • 232 Answers
SOURCE: I'm seeking the wiring schematic for Carrier
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/48gs,gx-7si.pdf
Posted on Sep 12, 2009
SOURCE: Carrier air conditioner isn't cooling the house.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Posted on Jun 25, 2010
shastalaker7
  • 1515 Answers
SOURCE: im not getting enough cold air in my house to keep
Hi, I will give you some things you can do as far as some service on this unit. What happens, is when the ambient temperature rises, so does the internal freon pressures in the system which in turn, causes the unit to work much harder and at a 95f degree ambient temperature, most all residential units loose up to 45 to 50% of there efficiency!! This is a fact. Then you walk into a shopping center and its over 100 plus outside and a nice 72degrees inside, so you start wondering why my unit is not that cool. Well, being a A/C, Heating, & Refrigeration Contractor for 33 years, I know what goes on. Most all home units as I say are made to work good up to about 95 degrees ambient. This is for a 2 to 5 ton unit. 1 ton of cooling is 12,000 btu's, while on the roof of these shopping centers and strip malls they have 15, 25, 75, and even higher tonnage units!! So back to yours, I just wanted you to learn a little about the size and tonnage of a unit. You can do this first. It's showing you have a complete package unit, all in one not a split. I don't know when the last time you had it serviced but, take your garden hose, kill the power to the unit first. Go to the unit and the wrap around coil give it a good washing out. They make a coil cleaner but you have to be a contractor to buy it. Water will be fine. This should be done once a year in the Spring. Careful not to bend the aluminum fins flat on this coil, but do clean it very well. Dirt is drawn in by the condenser fan motor on top. Start washing from the fan area out first, and go around the outside and wash in. Do this until you see no more dirt, as this is very important. This keeps the high head pressures down to normal in your system, and if its dirty you can lower this high side pressure up to 100 p.s.i. The unit is made for outdoors, so don't worry about getting it wet. Try not to spray water on the main electrical box of course. Keep your filter cleaned or changed as this is also very important. Here is a rule of thumb I will tell you about air conditioning temperature you will know. If you can, pick you up a dial or digital type pocket thermometer at a hardware store, and take these readings at the supply air vents,1 or 2 of them and record it, and at the return air which is where the air returns back through your air filter. This is called your temperature split, or TD (temperature difference). If your unit is running properly as far as freon charge and so on, it should be between 18f to 25f degree difference!! Any higher or lower indicates a problem, low on freon, compressor valves are weak, plugged evaporator coil or dirty filter, many things, dirty condenser coil. Check this before you wash out your coil and let it run and dry out first, and recheck to see what you have. Your unit runs 24/7 trying to capture the load and can't keep up. May be do to age, or just needs some TLCare. So again, the TD check, lets say your supply air coming in is 58*F. Your return should be close to 76*F to 83*f, a 18 to 25*F degree difference. 18*F to 20*F would be awesome, but this is the rule of thumb we use. If it's 105* outside, you will be lucky to have a indoor temperature of 80*F!! A 25* difference. If after recording all of your temperatures and noting them, cleaning the condenser coil and making sure the filter is clean, after the unit runs for 1/2 an hour, recheck the sa&r/a and see what you have. If the coil was very dirty, this may have solved your problem. If after all of this, you may need to have your freon level checked, lets hope not. I have a feeling that it is in need of a good service. Please keep me posted on this, and I am sorry for such a long answer, but I just wanted to share some things with you to remember. Please get back to me to let me know the out come and please rate me kindly as I know you will.
Sincerely,
Shastalaker7
Posted on Jul 29, 2010
I have a carrier air conditioner model 38CKC024340 it cool the house sometimes, then a block of ice will form on the unit outside and it stops cooling, what could be the problem
Have you changed the air filter?
The 2 main reasons for frozen units in cooling mode 1. Not enough air flow. 2. Low on refrigerant.
You can fix #1.
#2 will require a service call.
Jun 02, 2011 | Carrier 38CKC024 Air Conditioner
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
I have a Carrier Gas Pack Model # 48GS-024060301 and it's just blowing cold air. The mechanic said that it would cost me $500.00 to repair it. Is this reasonable?
1ST OF $500 IS THE 1AT RED FLAG!!!
2ND U NEED TO HAVE HIM CLARIFY IF ON THE QUOTES REPAIR
3RD THE QUESTION TO TO VAUGE
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
