Question about Proscan PS50700 50" Rear Projection Television
My tv shut off and wont come back on all it does is beep what is the problem
  • Proscan Master
  • 1,213 Answers
Hmmmmm. at the easiest point i would certainly find a bad capacitor or two. Alwasy suspect a 160 volt to 200 volt cap at 1Mf, 2.2Mf or 4.7Mf. Another suspect would be the 200 volt 100Mf caps that are somtimes used in theses TV. You do have a problem in the the horizontal section. Start with the capacitor check and check for bad grounds. It is the board that contains the high voltage transformer [flyback]. It is this board that will be reworked. Ask a tech, you have some knowledge of the problem and this will keep your cost of repair in your favor. Your proscan TV is a sister model of the well brand known brand, RCA! Hope this helps and thanks for asking!
Posted on Aug 02, 2010
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Computer shut off by itself and now wont come back on?
Does it beep? If you know how to install memory try removing all memory then power on do you hear beeping?. Install one of the memory try power on. Make sure CPU fan is working.
Oct 19, 2014 | HP Compaq Presario SR5350F Desktop PC...
Sony Trinitron Tv shut off then made two beeping sounds and doesnt turn on anymore
Two beeps can be considered as two blinks. Blinks of standby light in Sony TVs are fault indications. Visit the site linked below to know more about the blinking codes and fault locations to Sony TVs. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 30, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My RCA 52 in Projection tv just shut off and its beeping? It wont go back on just beep's
A model number is not indicated on this question--it would allow me to try to help.
May 03, 2012 | Televison & Video
My tv wont turn on and its beeping
Unplug the set, press power and hold for 60 seconds, let it sit for 30 minutes and plug the TV back in, try to power on, if no change! the problem is power supply or high voltage issue.
Mar 21, 2012 | Televison & Video
Had the ps3 working fine, plugged it into another tv and nothing, the tv wont pick up the signal.. went to plug it back into the 1st tv and still nothing
Try resetting the display back to standard definition -
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
Wait for the PS3 display to reset
Hope this helps
Oct 26, 2010 | Sony Playstation 3 (PS3) Console
Tv wont stop beeping every time i turn it on. It is a very high pitch beeping that doesn't stop. I have tried plugging the tv in several different plugs by itself but the beeping still didn't stop.
Ur High Voltage is dead.The FBT the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced the FBT get power back.
Jan 19, 2010 | Televison & Video
I set up my ps3 on my hd tv, have now tried to set it up on a normal tv at my mums house and it wont connect to the tv!!??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try a video reset.
1:Turn the system to off/standby, where only the red light is on.
2:Then hold your finger on the front power button, it will turn on beep twice then shut back off, release finger.
3:Then turn back on normally.
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Wont boot up,no picture or sound on the tv.
when u switch on your console try holding your finger on the standby button untill u hear it beep , i think it beeps 3 times this will put it back to the origional settings incase you have accidentaly switched it over to hdmi
Aug 11, 2009 | Sony Playstation 3 (PS3) Console
Proscan PS50700 50" Rear Projection Television Logo
105 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
