X6570 doesn't have OCR installed. - Office Equipment & Supplies
  • 319 Answers
Www.smallbusinesscomputing.com/.../Affordable-Wireless-Printing-Lexmark-X6570-All-In-One.htm
Posted on Aug 02, 2010
My Canoscan 4200F has no OCR software. How do I get it?
OCR software is usually a third-party program. Sometimes it is available on the original driver CD but it isn't included in the downloaded driver software. In the case of the CanoScan 4200F, the CD included the OmniPage SE OCR program. The SE indicates a Special Edition only bundled with the scanner and was only available for the OS versions that had been released when the scanner was first available. If you have the original CD (for Win98-XP), try to install the program using the Custom install option. (Check your current OS version. A 32-bit OS is more likely to support the OmniPage SE. With Windows Vista and 7, click Start > Control Panel > System and Security > System to determine the version. x64 indicates a 64-bit OS. ) If your current computer doesn't have an optical drive, use an external optical drive to install the program.
If you do not have the CD or your OS is incompatible with the Omnipage version on the CD, you will need to either purchase OmnuPage ($99 with a rebate from many vendors), AbbySoft's OCR program or one of the other OCR programs. SimpleOCR is free for personal use, http://www.simpleocr.com/Info.asp . The biggest problem with the free OCR programs is that they do not handle documents with columns properly.
I wish that I had better news for you.
May 31, 2012 | Canon CanoScan 4200F Flatbed Scanner
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
How to use the ocr
The function to do OCR scanning will be part of whatever scanning software you are using with this printer. Probably some scanning software came with the printer. If it doesn't have OCR capability , you'll have to use some third-party software. Just Google OCR software.
Jul 18, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How can you scan using OCR it comes in unreadable do I need some other software installed to use the OCR function ?
On OCR software we can only scan a full text documents. Document that doesn't have any line, image, graphic. Try to scan a full text document and check if that will work.
Hope this helps. Rate if it works. Thanks
May 03, 2011 | Canon Office Equipment & Supplies
Ocr for productivity studio x6570
if you don't like to install ocr software to your computer, you can try this free online ocr tool
Sep 13, 2010 | Lexmark X6570 InkJet Printer
I have a lexmark x6570. It's asking me to install
you're going to need the installation cd for that OCR software. It can't be downloaded online since it's a big file. You might want to call Lexmark on their toll-free 1-800-LEXMARK for the cd. Hope this helps.
Feb 25, 2010 | Lexmark X6570 InkJet Printer
Fax driver issue
Same problem. I was using the cjb6500en.exe file which does not contain the OCR and FAX drivers. Use the installation CD and select Custom->Update Driver and Install Optional Software to add the FAX driver.
Nov 16, 2008 | Lexmark X6570 InkJet Printer
k24674
jasbo
jasbo
Marvin
Marvin
