Question about Kenmore Dryers
Just had the dryer on went to change clothes over and they r still wet but now it wont come on u can hear it click when u hit the start button but thats it
    Brigadier General:
  • 3,301 Answers
Look through the sight hole to see if the glow plug is lighting,, ( a bright orange color) if it does it means that the solenoids that control the gas release are not working and the glow plug will shut itself off,
Posted on Aug 02, 2010
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and...
i had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Jan 03, 2011 | Dryers
I HIT THE START BUTTON AND YOU CAN HEAR IT CLICK BUT NOTHING HAPPENS.
take dryer apart and look for a reset(break belt switch) on the motor:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 25, 2010 | Whirlpool LEQ9858P Electric Dryer
The dryer was working and the electricity went off and came back on while I was outside. I thought it was done, took out the lothes and put in new wet clothes, turned the timer knob and hit the button. It...
Try resetting the dual breakers for the dryer in the house electrical panel--push off, then on. Power surges from the utility can cause the breakers to trip. If this doesn't help, then you probably have a problem within the dryer. Good luck!
Feb 06, 2010 | Dryers
My dryer was working. I stopped it to take my clothes. When I went to put in the wet clothes my dryer would not start.
Try pressing on the door to close it and
see if it starts. It sounds like the door switch has failed or the actuating arm is bent. You should hear a click as the door just barely opens or is nearly closed. No click = no start. I.e. Door switch problem.
Jan 22, 2010 | Whirlpool GEW9250 Electric Dryer
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Dryer wont start
Hello. i can help you. begin by checking the power.
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
If that doesnt get it working again get back as there are other things that could have gone wrong.
Jun 04, 2009 | Dryers
My whirlpool dryer is dead
Most newer dryers have a thermal fuse link which prevents them from producing heat if it has overheated due to lint build up. Safety! Remove the back of the dryer after you unplug it of course. Look for a white, two connector, block about 1/4 by 1-1/2 inches, mounted to the back of the heat transfer duct. Remove both of the wires from the the connectors and test the fuse for continuity. Multi meter needed. This should show 0 Ohms. If there is no change on the meter than this fuse is bad. Most any appliance parts place will have in stock. $12 - $15 Clean out as much lint as posible from the exhaust opening with a vacuume and reinstall the back panel.
Nov 20, 2008 | Whirlpool LER4634J Electric Dryer
Problem with top dryer on stackable frigidaire
The switch may be bad or just not engaging when the door is closed. To test it you could tape something to the inside of the door right where the door meets the switch and see if it comes on. I did that and it worked. I use it as a temp. fix.
Jun 17, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Mar 30, 2008 | Dryers
Dryers Logo
23 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
