Question about Seiko Melodies in Motion Clock
My clock keeps time, melody plays on the hour, but the other motions will not move. It is one that the fack goes into a cross with figures making music in all four corners. We have changed the batteries and that doesn't help.
  • edandglenda Aug 03, 2010
    It seems to me that a clock that cost this much from a reputable company should not be unrepairable. Isn't there any other solution?
    Clock has not been abused, hanging on the wall in the same place and not moved except to change batteries.
    Guru:
  • 825 Answers
The PCB that works as a relay unit is gone bad... you can find the particular relay unit in any part stores...you can replace the part by yourself and make it to work as before...
Posted on Aug 04, 2010
  • 6,826 Answers
The motor can run dry of oil or grease when the clock gets older causing this problem. It's a nice clock, but probably not repairable.
Can you tell me how long you've owned this clock?
Posted on Aug 02, 2010
My mother-in-law has a Melodies in Motion Clockpost Willie clock that she no longer has the instructions for. She can't figure out how to make him whistle. Can you point me to an ownder's manual?
Hello, Sherry -
I have not been able to find instructions online for the Seiko Melodies in Motion Clockpost Willie (a clown figure standing along side a clock on a post.)
The Melodies in Motion clocks are manufactured by Seiko Clocks. This is the link to the Seiko Clocks home page:
https://www.seikoclocks.com/
Near the bottom left of the home page, you will see the link to Customer Care. Click or tap on that link.
On the Customer Care page you will see the toll free phone number and the email address to use to ask if the instructions for the clock are available and how your mother can obtain them.
Best wishes.
Feb 23, 2018 | Home
Why will my clockl no longer play song or move
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling
UsedClockParts.com
Sep 02, 2014 | Seiko Melodies in Motion Clock
I recently moved my melodies in motion clock back one hour for daylight savings time and now the clock is not keeping time. I suppose I should not have moved it backwards but now what do I do to get the...
By moving the clock back one hour you changed from DST to standard time, not as you stated. Some clocks require you to rotate the hands clockwise to set the time back. Your clock may have been damaged beyond repair.
Nov 05, 2013 | Seiko Melodies in Motion Clock
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
How to change the hour
Anniversary clock hands can be adjusted directly moving the minute hand clockwise. Do not touch hour hand as this may cause hand disalignment. Carefully move minutes hand with your finger all the way around till you reach desired time.
Do not forget to rate, please.
Mar 09, 2009 | Seiko Clocks Melodies In Motion QXM135BRH...
Seiko Melodies in Motion Clock Logo
162 people viewed this question
Top Seiko Home Experts
k24674
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Home Expert? Answer questions, earn points and help others
