Question about Canon PIXMA MP750 All-In-One InkJet Printer
Dead Printer just died in the middle of ink cartridge being changed. No obvious lose of power All cords seem intact'
  • williewil546 Aug 02, 2010
    where is the advise Cannot open site suggested. Click on and nothing happens. please send any advice to williewill@telus.net as I am not getting yours words of wisdom. Thankyou
  • 319 Answers
Www.smartcomputing.com/editorial/article.asp?article
Posted on Aug 02, 2010
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
This is my first time changing the ink and i cant seem to find the instructions. I don't know how to change the ink. Please help
Check this article(How to Set Up the Lexmark X3600 or X4600 Series All-In-One) from the Lexmark website: http://bit.ly/cI3Ekr. Scroll down and go to Step 9 for the instructions on how to install/replace the cartridges. Printer should be on.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Sep 22, 2010 | Lexmark X4690 Wireless InkJet Printer
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
Printer says to change the black cartridge BUT the cartridge carrage is way to the left and won't move to the right so I can get at the black cartereridge. Service # B017869
Call kodak > Printer needs to be replaced
IF you need to print urgently
Open the access door > Disconnect the power cord > Then connect is back > As soon as the carriage comes in middle > again disconnect the power cord > You'll be able to change the ink cartridges
Feb 05, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Any idea why all of a sudden my printer won't accept my ink cartridge? The power light keeps flashing and won't let me print. I have checked the cords, uninstalled and re-installed the printer and even...
I presume that your are replacing the ink cartridge with a new one. Although this may seem obvious, be sure that all removable tapes around the printer head have been removed. Sometimes this is not so obvious.
Oct 31, 2009 | Dell 810 All-In-One InkJet Printer
1200 error
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
YAY problem fixed.
Hope this might helpful to you.
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error #1200
if that doesnt help...
remove the shell from the black base, clean the goop from under the ink cartridges, put silicon on the bars after cleaning with alcohol, grease the gears sparingly, put it back together,
good luck
Jul 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Pixma MP780 Can't turn on
To move the print cartridge without power to the printer: Grab it with your hand and slide to the middle. It may offer slight resistance and while not an expert, I doubt damage will be caused.
Feb 03, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Erropr code #1200 Lexmark X4270
Tried what blkghost suggested above but had to tweak his advice slightly.
YAY problem fixed.
Nov 02, 2007 | Lexmark X4270 All-In-One InkJet Printer
Flashing lights
That flashing pattern is consistent with a stuck carriage. Here is a copy/paste from HP concerning the 5000 series and your flashing lights.
Issue
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Close the cartridge flaps after removing the ink cartridges.
4. Turn the printer off, then on again.
5. Replace the ink cartridges.
6. Close the top access door. Issue
The Resume light continues to blink after the cartridges are released.
OR
The carriage is stuck or makes a grinding noise.
Solution
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
5. Take out the cartridges and close the top cover.
6. Reconnect the power cord to the back of the printer. Plug the power cord to the wall outlet.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
Canon PIXMA MP750 All-In-One InkJet Printer Logo
115 people viewed this question
old marine
old marine
