Question about Garden
I am looking for a battery for mastercraft weed eater et-d1801
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
Dolfoff
  • 148 Answers
SOURCE: looking for information on a weed eater riding mower
On the center of this page click "Parts Look Up".
Next, Change the tab at the top to "MODEL".
Next, Drop the "Select OEM" menu down and choose "Electrolux Home Products".
Next, Under "Model Search Criteria" select the option "Contains" .
Next, Under "Model Name / Number" type in we12542 (do not use spaces or dashes).
Next, Select the proper letter-code that is listed on your machine. (Same info sticker you found your model number on.)
Next, Select the specific component drawings which will be listed on the right side of the page.
Hope this helps
Posted on Sep 28, 2009
  • 14 Answers
SOURCE: my stihl weed eater will start but not rev up
little cable with toggle on the end of it, this has come off the carb
Posted on May 10, 2010
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
Craftsman battery powered weed eater quit working
How old is the weed eater? Does the battery need recharging?
Jun 12, 2017 | Craftsman Garden
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Air filter replacement weed eater
on your weed eater there should be a lil bubble looking thing called the primer somewhere around tht should be a black box with a screw of some sort on it take the lid to the black box of and theres your air filter
Aug 17, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
How do I remove the spoolhead so as to afix the pivotrim head
I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
Enjoy! :-D
Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
Where can I buy battery ET-D1801
Try batteries plus or somewhere similar in your area. Good Luck...
May 28, 2011 | Garden
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
What's my Weed Eater's Model Number?
Model # is featherlighit plus. that is what I would need to look up parts
Aug 06, 2009 | Garden
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
331 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
