Question about Bissell SpotLifter 1716 Bagless Handheld Vacuum
I bought an spot bot last year. It makes an grinding noise when I clean my rugs. Yes there is liquid in it. where can I have it checked on
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49876&thid=544924
I bought a spot bot
Posted by duchie1948 on Apr 25, 2008
Bissell Spot Lifter #1716 Bagless Handheld
I bought a spot bot last year. It makes a grinding noise when I clean my rugs. Yes there is liquid in it.
Where can I have it checked on?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on what you paid for it would determine the cost of repair and or labor, typically the item has a one year factory warranty and you would have to check with the manufacturer to see what the warranty is and I will list the Bissell Factory Manufacturer below. The grinding noise could be that you have a build up of dirt in the motor or a broken fan blade or fan, and sometimes it may be cheaper to replace it than to repair it due to the cost of the part and the labor to install. Just a suggestion….
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 25, 2008
  • pulsev2 Dec 24, 2010
    Ours started making a loud grinding noise and aparently one of the clear suction nozzles on the bottom had broken off and gotten wedged in the machine. After removing and buying a replacement nozzle from bissell for a couple dollars, back in business. If the noise is excessively loud, I would avoid running the unit until repaired.
My Bissell Spotbot Pet cleaner stopped working. Took it out of the closet, plugged it in, No power? It worked great the last time it was used.
Well, if cycling it manually doesn't work and replacing the controller board didn't make a difference did you check the flex hose sensor? Bots won't run unless everything is clicked into place.
"Testimonials" don't continue the thread :)
I managed to dig up a copy of the service guide since I haven't owned a spotbot in years. http://evacuumstore.com/images/spotbot-repair-guide.pdf
Mar 22, 2017 | Bissell SpotBot Pet Spot Cleaner
Spot bot turns on and makes a grinding sound but doesn't work
motor is jammed bring it to me at 206 west lordeman kokomo Indiana 46901 or call 765-236-7524 and ask for josh I will fix it at little to know cost to you
Mar 21, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
Motor making grinding noise and burning smell
A bit too late I fear. There is either grit from an overloaded dust bag in the motor or the brushes have worn out. Spares and not expensive.
Jun 10, 2017 | Hoover H3044 FloorMate Hard Floor Cleaner
Spot Bot leaves mold rings
Hey, the mold ring is showing the carpet is now clean in comparison to the rest of the room.
You may want to have the rest of the carpet cleaned using a BISSELL deep cleaning machine or by calling a professional.
Jan 27, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brush does not rotate for cleaning rugs.
have you tried pusing in the little red buton on the side of the brushes cos if thats out they wont work
Jun 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Spot Bot leaking water from reservoir through brushes
make sure that your collection tank is empty and correctly attached. If it is full, it will shoot water on the spot, but not **** it up several times in the cleaning process leaving a large wet puddle bigger than the original spot.
Mar 16, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
When I turn on the spot bot it immtediately starts beeping and won't stop
A sensor for the motor is malfunctioning. It is under warranty for a year.
Nov 28, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
My Bissell Cleanview Bagless vacuum makes loud grinding noise.
the ends of the roller have something wrapped around them.see if you can pull the ends off so you clean the caps and bearings
Apr 09, 2009 | Kenmore Progressive Bagless Upright with...
Trouble with Spotbot
My problem wasn't a problem with a new unit. We have had ours over a year and it has been flawless up until a few days ago. Ours stopped pumping cleaner for both the manual hose and the automatic section. Other solutions of priming the pump described make sense, but that was not my problem. When I would press the manual hose button a very short squirt of liquid would occur and then nothing. When I looked at the receptacle for the cleaner tank on the Spot bot side, there was a gray fuzz in there. I tried cleaning that with an old toothbrush and it came right out. It was a filter of some sort. It was gray on one side, black on the other and about the size of a dime. I guess over time the filter has gotten clogged and didn't allow a full flow of liquid. I removed the filter and put the tank back in. The unit works perfectly. I am going to try to clean the filter, put it back in and see if the unit will work. If not, the filter is history.
Jan 14, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotLifter 1716 Bagless Handheld Vacuum Logo
186 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
