Question about Cell Phones
Q7 bluetooth will not turn on
I was given a q7 bluetooth headset and have charged it for 2 days now. Holding the button down does not work to turn it on neither does just presssing the buttons once either. I just need to know how to turn t on.
Press for 6 seconds continuously
Posted on Oct 07, 2010
When I plug up the bluetooth to charge the red light appears then it blinks blue red does that mean it is charging or not because it is not working with phone
That might meaning that's it's draining the residual charge left on the battery, before it can be charged, but if it does this for more than an hour, your battery is "toast".
Aug 28, 2014 | Universal QuickCell Q7 Bluetooth Headset -...
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
Turtle beach black ops 2, bluetooth not working
im having the same issue with the tango edition ,im holding the bluetooth button down and no turn on but the everything else works ???? any solution
Dec 20, 2012 | Turtle Beach Call of Duty Black Ops II...
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Need driver for Samsung WEP450 bluetooth for Windows 7 - 64bit?
Since the device is Bluetooth you should not need any drivers. Make sure you have charged the earpiece fully, and that it is ready to connect (most of the time that is just a matter of holding in the lighted button until it blinks and then is solid once you stop holding it down). Then make sure bluetooth is set to discovery on your Windows device. Most times to do this you just need to enable bluetooth. You can do this from your control panel. Hope this helps. Have a great day.
Dec 07, 2010 | Samsung WEP450 Bluetooth Headset - Retail...
I just bought my madcatz headset from the shop. Charged it for 4 hours and the red LED turned off so I suppose it is charged. Then i go to the “Manage Bluetooth® Devices.” and go to the screen where...
The power button is not the right button to press.
Here is the steps I take:
1. Power on the headset
2. Have PS3 scan for new devices
3. Hit the tiny button that is next to the volume buttons on the top of the headset.
4. PS3 should recognize "8860" and ask for a passkey which is "0000" by default
5. Paired and ready to go
Aug 26, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Can't pair bluetooth
....My madcatz bluetooth will not charge everytime i plug it in the ps3 the red light comes on then it goes off and it keeps on doing it and its a brand new bluetooth...i hold it for a long time and it still wont work..HELP PLEASE!!!!!!1
Feb 06, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Bluetooth headset doesn't hold a charge very log
hold call button down till it blinks, than youll get intermitant light for about 30 seconds, than youll know its on. to turn it on hold call button down till it starts blinking at least 6 seconds. to turn it off hold call button down , itll blink for about 3 seconds than move your thumb off and when it ceases to blink its off. good luck
Jan 12, 2009 | Jabra BT350 Bluetooth Headset Headset
Pairing my headset to the PS3
Ok people, here is how it is done- Turn off your bluetooth. When it is off, press and hold the main button (power button) until it flashes(keep holding even after it flashes). The light on the device should turn solid blue (instead of flashing) now you can let go of the power button. My device was picked up immediately... after 2 hours of trying to figure it out of course, lol. Hope it works for y'all!
~Live long and prosper ;)
Jan 06, 2009 | Radio Communications
Bluetooth problems
Holding down the main button while my phone searched for devices found it. I entered 0000 for the passcode and it connected.
Apr 19, 2008 | Motorola Mobility Bluetooth Hands Free...
Cell Phones Logo
563 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
