Question about Telex Radio Communications
Hi, I am Kush Agarwal and I have been using the telex airman 850 for a while now. Just a couple of days back I noticed that the right side speaker of my headset is not working properly. The sound and the noise cancellation were both intermittent, but would come back with some wire adjustments. Looks like a loose connection some where. I am in India, and so its not really possible for me to send the headset to US for repairs. I would like to know if there are any service centres for telex in India, or maybe a do it myself fix. Kindly advise how I can fix it. Thanks in advance, Kush Agarwal.
    New Friend:
    Problem Solver:
  • 6 Answers
Old question, but may be somebody else is experiencing the same issue. The earcup without the boom has a noise cancelling board, so it could be one of the wires that goes from one board to the other one. Gently take the earcup off and look at the 4 wires that are soldered on top (red, black, shield and white). If one of these is cut, the speaker/anr won't work. You will need a very small soldering iron to repair it (no more than 15 - 20 watts). Good luck, hope this helps ;)
Posted on Sep 13, 2015
4 Suggested Answers
SOURCE: L9 headset
turn up the volume on the left hand sign on ur phone
loook for the code at the back on ur fone and try repairing it..
hopefully it will work :)
Posted on Jun 01, 2008
SOURCE: There is no sound of the left side of the headset
Probably just need to manually reconnect the wires with a pair of tweezers. Work's for me sometimes. It's a pain in the a$$ though
Posted on Apr 28, 2010
  • 1015 Answers
SOURCE: In recent days my headset (590A) has only been
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Posted on Oct 15, 2010
Sound became muffled(only lower frequencies) in both ears
An equalizer circuit or filter? No idea where this would as you only give the result not total environment.
Apr 01, 2014 | Telex Airman 850 Aviation Pilot Anr...
Does not work with telex 850
Don't know if you are using the PA-97 adapter, it should work without any problems. I would check the potentiometer "gain" adjust on the microphone assembly. Hope this helps ;)
Jan 30, 2014 | Pilot USA Fixed Wing Headset to Airbus...
I have a telex airmen 850. I tried calling to see if it was still under warranty- with no help. It's $200 flat rate fee to ship it there... Is there somewhere else I can send it to be fixed? It was working...
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
Apr 19, 2011 | Telex Radio Communications
Logitech Z4 sound from one side only
Reconnect all the wirings in your speaker set. Be sure you connect all the cords properly.
May 25, 2009 | Logitech Z-4 Computer Speakers
Telex 56 to cobra 4 pin
Hi there!!
the yellw wire is not used on the microphone conector most of them are just cut and left in there loose as long as its not shorting out on anything!! The wiring for the telex 56 for your radio Cobra 29 LTD is as follows: PIN #1 Shield & Red, PIN #2 White, PIN #3 Blue, PIN #4 Black, Yellow wire not connected!!
If you notice when you have the connector apart on the back of the pins where the wires get soldered to the pins are numbered so you will know which pins they are or on the front side of the connector the pins are also marked wich numbers they are!! If you have any other questions please feel free to e-mail us at: bigdscbshop@hughes.net
Apr 18, 2009 | Telex M-560 Consumer Microphone
Telex prostar wireless mic.  leads came off of mic element.  One green wire and one black.  Which one connects to center of element and which connects to rim.
Hi..
The rim is "ground" or the (-) side of the mic.
Find out which wire goes to ground or a (-) on a battery.
Solder that one back to the rim
Dec 11, 2008 | Telex FMR-200H Professional Microphone
Telex copyette 1-2-3 you can hear both sides at the same time
Clean the heads, oil the spindles.
Basic problem is the tape alignment is off a little. Could be caused by too much tape tension causing it to wander.
Hope Ya Fix It. So ya can spread the word!
Feb 07, 2008 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
Orion standard tv
Have you had any kind of magnets close to the tv set? I had a brand new sanyo do the same thing. I had pulled the speaker box out of my truck and stood it up next to the tv (not thinking about where I put it). Turned it on a few hours later only to see a messed up picture. I moved the speaker box to get behind the tv and the picture got better. Moved the speaker box back to the truck and after a couple of days the picture was back to normal. These were 4 large magnets on these speakers. Maybe I helped some!
Mar 08, 2007 | Orion STV2763 27" TV
Radio Communications Logo
357 people viewed this question
Top Telex Radio Communications Experts
Andrew Taylor
Andrew Taylor
richie46
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
