Question about Hoover F7452-900 SteamVac Upright Vacuum
Constantly sprays water
I noticed recently that our Hoover F7452 All Terrain constantly sprays water. As soon as I turn it on, whether or not it's set to Rinse or Auto-Rinse, it's leaking water at the brushes. I probably wouldn't have noticed but I attached the hand-held adapter to clean our stairs and when I was done there was a HUGE pile of water under the vac. I took everything off and cleaned really good and looked again this morning and it's still doing it. Any ideas?
  • Anonymous Jan 19, 2009
    Water leaks out of the brush area as soon as tank is installed
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=515776&thid=544922
Posted by elstretcho on Apr 25, 2008
I noticed recently that our Hoover F7452 All Terrain constantly sprays water. As soon as I turn it on, whether or not it's set to Rinse or Auto-Rinse, its leaking water at the brushes. I probably wouldn't have noticed but I attached the hand-held adapter to clean our stairs and when I was done there was a HUGE pile of water under the vac. I took everything off and cleaned really good and looked again this morning and its still doing it. Any ideas?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You probably have a bad trigger release valve or a loose connection @ the bottom of the SteamVac or the gasket under the solution tank in not sitting on there right and is leaking or you may have a small cut in the hose, but it so may guess that it is a bad trigger release valve or a bad gasket. Check with your local vac dealer to see if they have a new or a good used one to see if there is the problem or back track the problem from the bottom to the solution tank. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 25, 2008
Will spray water, but not solution
Hi there! The clean water tank has two spring loaded valves that releases the contents. Fill the clean water tank with water on both sides. Hold the cleaner up and push the valves in on both water and solution side. Both valves should push in and contents should drip out. If not, the clean water tank will need replacing. To order a replacement tank follow the link. Search Results The type of solution you are using can also prevent the solution from dispensing, be sure you are only using the recommended cleaning solution for this cleaner. If the clean water tank valves seem to be working fine, there may be an issue with the pump assembly that delivers the solution. We would recommend taking the cleaner in to an authorized repair center for service. To locate the nearest service center to you follow this link > Service Center Locator Hope this helps!
May 31, 2014 | Hoover F7452-900 All-Terrain SteamVac
Water dispenses without pulling trigger. How to stop it?
you should have a lever which controls this spray slid it all to one side then the other sometimes its just trial and error if this doesn't work then see if it has a cut of valve if so it may be broken
Apr 10, 2014 | Hoover F7225-900 SteamVac V2 Upright...
How do you replace the brushes on a hoover f7452-900
You have two model numbers showing. I could not find anything on the F7425-900, but I did find an exploded view of the F7452-900 If you go to this URL:
http://www.ereplacementparts.com/hoover-f7452900-steamvac-all-terrain-parts-c-37315_37419_37439.html
you can see the exploded view. This itself does not provide directions on changing the brush, but it does indicate that by removing a few screws on the brush and squeezing some plastic tabs (looks like any way) that you can pull the brush off. If you have the new brush already, it may indicate some of the connection points.
Hope this helps a bit. Paul
Oct 05, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
My brushes on my hoover steamvac all terrain carpet and hard floor cleaner will not spin what do i do
I am not sure if you have the F7222 or F7452 all terran. There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts below follow the link. Please don't forget to give positive feedback.
Hoover F7XXX Link
http://www.usavacuum.com/Hoover-Steamvac-s/107.htm
Jan 29, 2010 | Hoover STEAMVAC VACUUM Vacuum
Hoover steam vac..F7452-900. not working in wash-auto rinse mode
This problem sound like you hav a problem with the pump. I would take it to a shop for service
Sep 26, 2009 | Hoover F7452-900 SteamVac Upright Vacuum
Trigger on hose attachment not working so water sprays constantly
from your description, the trigger sounds like it is stuck in the release position. this sounds like a very simple repair. The component parts need to be looked at by a service shop
Jan 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water & soap spray constantly even when trigger is not depressed.
The connection for the hose to the cleaner is also a valve assembly. There is a white plastic spring- loaded sleeve that the hose must push in for water to flow into the hose. Part # is 43523004. This is a rather flimsy part, mine cracked and cleaner continously leaks out the backside of the valve housing until the tank is empty GRRRRRRR!
www3.sears.com there are diagrams and parts lists for similar model F7452-900.
Nov 15, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7452-900 SteamVac Upright Vacuum Logo
377 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
