Question about Canon imageRUNNER 2200
I have an IR2200. At the top of the page, there are black dots. There are 3 lof them and they are about 1 in apart. Could someone please tell me how to fix this myself with out calling for service? Thanks!
  • 1,219 Answers
try to print something out.If the dots arent on the printed page, that means that you need to clean the optics ( beneath copy glass ).
If you are not able to print, open front cover, realese the blue handle for duplex, release the handle for toner station, unscrew one screw on front of drum unit, remove drum unit and check for dots on drum surface, or for damadges on charge roller ( the black/grey roller on top of drum ).
Its probably drum unit fault, but it also can be fixing film in steak.
hope that helped
Posted on Aug 03, 2010
4500 Phaser -What causes black dots left side of page?
Sounds like something stuck on a roller with a diameter of ~1/2" diameter.
Good luck.
Jun 10, 2014 | Xerox Phaser 4500 Printer
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Timing chain marks needed for Audi A4 B9 1.8tfsi 2009 model. Engine was taken out and settings not marked. This is extremelyurgent. Please help
diagrams I have show a twin cam set up with 2 balancing shafts. The marks on the cam shaft point to (left cam shaft 11 oclock the mark on the right point to the 1 oclock position. The chain will have 3 black links-- the top black links will be at the timing marks on the shafts with the 3rd black link directly at 6 oclock facing a mark on the gear. The balancer marks both point to the 1 oclock position with black links on each and the 3rd black link will be facing a mark to the 7 oclock position on the crankahaft gear. Everything is done with the piston at TDC no 1 cylinder so get it there before you put the cam shafts in position or you will bend valves. Crank shaft gear is not keyed to the crank shaft. there are dots on the right hand balancer shaft gears and these dots will be as the 2 dots on adjacent teeth either side of a dot on the meshing gear. I suppose that is all as clear as mud but if you got this far then you will see the marks and marked links on the chains
Dec 22, 2013 | Cars & Trucks
Prints black dots at bottom of page - photoconductor was replaced earlier today
The black dots could be a few things, the most likely would have something to do with the drum area because the dots didn't appear until after service. If the dots are only about an inch apart it is probably the charge roller. If there is only 1-2 dots per page, the issue is likely with the drum. These figures are assuming you are running 8 1/2 x 11 paper with the long edge being fed in first. If this is the case, you can change the paper to feed with the short edge first and this may get you by until the technician gets back out to fix it.
Nov 18, 2009 | Ricoh Aficio 450 Copier
When printing the sheet of paper has 3 dots on the
Yes this could be the drum.
You could remove the drum and carefully look for the pattern of dots etc that you are getting on the page but on the drum surface.
I would suggest replacing the drum 1st and retrying.
If the black lines are just down one edge then the fuser could be to blame for the black marks but without being able to see the page i cant tell. The drum is certainly my 1st suspect and is easy for you to try.
If you are in Berkshire try www.repairmyprinter.co.uk for additional help
Aug 24, 2009 | HP LaserJet 2840 All-In-One Printer
Little dots on right side of margin (Brother HL-5040)
I would have guessed the trouble shooting steps you first performed. It could still be a bad imaging drum. Or a fuser. Not sure if this model has a replaceable fuser or not.
Jul 08, 2009 | Brother HL 5040 Laser Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Brother 5240 dots on prints 3-3/4" apart
turn the cartridge upside down on a table. turn the drum gear by hand and clean the spot with a dry cotton pad.
Jan 02, 2009 | Brother HL-5240 Laser Printer
Vertical dots on print output
1 1/2 inches apart would correspond to the diameter of the primary charge roller. You have one chrarge roller inside each toner cartridge so you need to determine which color the dots are and then replace that cartridge.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
Two black dots on right side of page
Are the marks in the same exact spot on each page? If not and you have changed the toner cartridge then most likely the fuser assembly needs to be replaced. This is a job I recommend for a professional.
Good Luck
John
Jan 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Canon imageRUNNER 2200 Logo
98 people viewed this question
old marine
old marine
