Question about Coby CX-CD375 CD Shelf System
CD Player spins very slow then stops. NO SOUND!
CD player appears to be dead but CD won't stop spinning
When a CD player goes south, it is almost always a given that the easiest and cheapest solution is a newer, higher-quality model. Just replace it. . .
Jul 26, 2017 | Sony Walkman D-SJ301 Personal CD Player
Ccoby-cxcd375 micro sterio system has a problem the cd spins no sound then it stops spinning why is this?
maybe is the optical lens, clean it with some cleaning disc if do the same the lens is bad and need remplace
Feb 20, 2011 | Coby CX-CD375 Personal CD Player
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Cd player stops spinning about 30 seconds after it starts. I opened the case and watched. It starts playing ok and then slows down and eventually stops.
Is it belt driven? My guess is that the belt needs to be replaced. If it's direct drive, it's probably the motor itself. Make sure you try some different CDs. Sometimes when there are scratches or smudges, the laser can't read the disk and it will stop. You may want to try a laser cleaning disk too. They are cheap and I have saved several computer drives by using one.
Dec 04, 2009 | Teac CD-P1260 CD Player
My cd player stopped spinning cambridge 88CD
Quite possibly is the motor if it is spinning on and off u need to clean lens or buy a new one!!!
Aug 20, 2009 | Audio Players & Recorders
Pioneer PD-F505 Cd Player - The player picks up the CD and it starts spinning. A high pitch squeel sound starts as soon as the CD starts to spin. The unit spins the CD for about two to three seconds and...
Sound like laser assy defected in any case you need a Technician from Pioneer or they are trained by Pioneer is very complicated to remove the laser and replace it you need an osilloscope to aligment a new laser and special disc to do that. It might not worth to repair it, the laser itself a bout $110.00 Aus
Nov 30, 2008 | Pioneer Audio Players & Recorders
Sony MHC-RG222 cd player broken
It is not clear from your post that whether this is functioning perfectly other than the sound problem, if it doesn't, change the laser pick up.
Feb 14, 2008 | Sony MHC-RG222 CD Shelf System
Coby CX-CD375 CD Shelf System Logo
233 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
