Question about Car Audio & Video
My JVC KD-G321 CD / Radio player has suddenly developed the following fault:- It will not play any CD's and the message '10000 A1' appears on the dispay screen. The radio still works but instead of showing the station name on the dispay it shows the message 'Y0000 AY'. The unit is just over 2 years old. Please could you advise if the fault can be corrected ? Thanks
  • jackieharry Apr 29, 2008
    This has happened to me. I have second hand stereo and no instuction manual. It plays the radio but not CDs and comes up with the same message as previous user states on the display screen. Any ideas how to solve this are welcome!
5 Suggested Answers
  • 130 Answers
SOURCE: JVC KD AVX1 car stereo
standard problem would be antenna issue. Make positive that the connection in the rear of the unit has a connection. If it does, take it out, slip a single, small wire in the back of the smaller hole [typically 1 ft long]. Although this results in an impedance ,ismatch, it will allow you to see if the antenna is at fault. With the wire in the hole, scan through the channels. Fixed? Antenna issues. Not fixed? You have an electronic circuitry or setup problem. Try the 'local' and 'mono' switch with the real antenna still connected. Still no reception?
This becomes an electronic issue at this point which stems at the following concerns:
impedance circuitry [usually small, diode at output]
PLL IC faulty or no V
Posted on Oct 15, 2008
  • 518 Answers
SOURCE: CD Changer Not Working - Please Help
THE CD YOU ARE TRYING TO PUT IN THE PLAYER MAY NOT BE COMPATIBLE, IT MAY ONLY PLAY CD-R CD-RW
Posted on Jun 13, 2009
josetejas
  • 300 Answers
SOURCE: Can you please organise me jvc kd-g415 car radio owners manual.
send me your e-mail ID. I don't know how to upload pdf josetejas@gmail.com
Posted on Nov 10, 2009
SOURCE: My car stereo won't store
i removed my car stereo and put a new one in, i didnt like the new one so i put the old one back in, but since i did this it wont store radio stations! why??? all the wireing is the same the fuses are all ok, so whats changed???
Posted on Jun 24, 2010
  • 11800 Answers
SOURCE: Hello i have a jvc
That error message appears when the speakers wires are disconnected or shorted. This is what almost surely happened with your radio: the the wires were undersized for the power, they got heated up really badly and the plastic insulation melted away, shorting the wires.
You will need to remove the radio, disconnect the speakers and redo the entire wiring to them using thicker wires.
Posted on Jul 11, 2011
Tip
Some information of DVD player for Audi A6
Audi always be a kind of luxurious and comfortable car, but the technological develop fast , the original function can't not meet the driver need now. So the special made Audi A6 DVD player come out. There is some information of Audi A6 DVD player for you.
The outlook of Audi A6 DVD player match the Audi completely. People will not think that the Audi A6 DVD player is not the original DVD player. The resolution of 800*480 will display the high effect of picture for you. The operation system and capacitive touch screen always make the operation easily.
The Win CE operation system can be operated easily. The Audi A6 DVD Player can react quickly. And the you can play audio and video by most of format. It will provide a high quality display for you. The Bluetooth function also help people a lot. If you want to connect some device you can find USB port in the side of Audi A6 DVD player which is the place you reach easily. you can surf by WiFi and 3G internet.
Hope these tip can help!
Audi A6 DVD Audi A6 Navigation Audi A6 GPS Audi S6 Navigation Audi RS6...
on Jun 17, 2014 | Car Audio & Video
JVC KD-R316 install in Valiant Regal I'm replacing the stereo in my car, it had an aftermarket system. The new unit has power and will show display and eject disc but won't turn on. Where did I messup
Envision how just a simple mouse pad could protect you from health problems that would definitely price you. Why not consider precaution when you still can other than offer with an issue, which you could have averted in the first place. Cell Telephone Accessories That You Ought To Have AmanStino
Jan 09, 2017 | JVC Car Audio & Video
Unlock cd radio vo73852
If you want a Ford V Radio code then contact this link: Car radio codes in Uxbridge London Gumtree
Jan 08, 2017 | Car Audio & Video
Try change my car radio cd .after connecting electric power and audio cable the new radio panasonic start 1 minute and stop loss power i reconnecting the old car radio ask me for cood the car is
You need to enter the radio code.....this should be with the service book or handbook, or contact the main dealer who will have a record of the code!
Jan 26, 2015 | Car Audio & Video
How to on bluetooth
KD-R200 does not have the ability to add Bluetooth to it
Apr 03, 2014 | JVC KD-R200 Car CD/ MP3 Player
Can't switch to the auxiliary
try useing it.. plug your aux cord into whatever your using (mp3 player) as maybe your radio won't switch to aux until it senses that there is audio being played through the input aux cord?
Mar 20, 2013 | Car Audio & Video
1992 GOLDWING RADIO SPEAKERS NOT WORKING
All you can do is trace the wiring back from the radio to the speakers, there is no quick fix here. To test the speakers touch a battery to the two contacts, the speaker will pop if it is any good.
Nov 06, 2012 | Car Audio & Video
Car Audio & Video Logo
151 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
