Question about LG 42LC2D 42 in. LCD HDTV
None of my main side panel buttons are working. I practically took the tv apart and started to jump the circuitboard. Only thing I found was the power jumper slot.. Any idea as to how or where to find channel switches?
  • 11,361 Answers
Gmc envoy 2003 driver windows not working
Take apart again, and clean all connectors and try again. Maybe some rust build up on connectors.
Oct 31, 2013 | Cars & Trucks
Blinks red wont come had it diagnosted tech says main board
I had same problem with my Hisense TV. I replaced the "Main Board" and it's working fine. I took the TV apart and got the part # off the main board and checked ebay...found one! Good luck.!!
Apr 09, 2013 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
HELP! Olevia lt37hvs screen went blank. No Sound, panel buttons wont work. Backlight is only on on half of screen.
if you had audio i wold say its most likely the Tconn or its upper two connections to the Panel itself. But since you dont have any sound either I would assume its either the LVDS cable from the main board to the Tconn or the Main board itself as audio and video are produced on the main board, You can get replacement boards from www.tvrepairworld.com
Aug 12, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Console lights up but when I press any of the buttons it won't start
I am having same problem. The console lights up but none of the button works, including TV and the fan.
I actually took everything apart, unplugged and re-plugged the connectors on the PCBs of both side of the console, it still didn't help. Looking at the electronic configuration, TV, fan, left and right panels are relatively independent. I believe the driver/motor module is still working, the most likely cause of this is the controller CPU.
Jun 05, 2012 | Reebok Vista Treadmill - RBTL13305
Dryer turns on but won't heat up or tumble
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Bosch Axxis WTA 3510 Electric Dryer
The sceen just bleaches out when powered on. Controls have no effect. TV is 13 months old.
I took it apart and found two 330 mfc 25volt swollen capacitors on the main board. I replaced them with 330 mfc 35volt capacitors and tv works like new.
Feb 11, 2009 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
Rca F32450
I CANT SIRSH THE TV
May 31, 2008 | RCA F32450 32" TV
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Dropped the camera, shutter won't closed, focus keep moving in and out, message "please turn off camera and turn on again"
This recently happened to me and I too got a hefty quote from the company since mine was no longer under warranty. I figured since it was trash anyways, I might as well take it apart and see if I could figure out what was broken. After removing all of the screws and removing the top pin strip from the board (there is a piece of tape on it) and flipping the lens part away from the board, I was able to remove the small gear compartment on the side of the lens housing (held on by one small screw) and the 3 screws on the back of the lens and carefully flip out the digital camera part and push the lens back into it's original closed position. I then carefully reinserted the digital part back into the lens making sure everything was nice and flush and closed it back up. Works like new :D However, if you're nervous about digital machines, I wouldn't reccomend doing this. Luckily for me when my camera fell it simply knocked the digital lens out from the housing and it didn't pop back in right afterwards, causing the lens to not be able to turn completely like it should. If yours is damaged more than this, it may not be such an easy fix. And the camera is difficult to handle as it is connected by those pin strips everywhere. It made me nervous to handle it as I probably could have made it worse, but, I had nothing to lose. Hope this helps out the next person.
Jul 27, 2006 | Panasonic Lumix DMC-LZ2 Digital Camera
LG 42LC2D 42 in. LCD HDTV Logo
49 people viewed this question
