Question about Targus (ACB10US) Bluetooth Wireless Adapter
When I insert Targus Bluetooth 2.1 installation disk and choose "Install Bluetooth Software (Windows 7/Vista) ... and I do have a Vista OS ... I get the message that no bluetooth device was detected. I'm a court reporter and have used this same install'n disk on this same pc, but had to install a new hard drive. I've tried inserting the BlueSoleil adapter both before and after the message appears, but nothing happens and I have to cancel the installation. Any suggestions?
  • 319 Answers
Www.fixya.com/support/t5449135-when_insert_targus_bluetooth
Posted on Aug 02, 2010
How can i find out what operating system my laptop came with originally?
It sounds like your laptop came with a OEM OS of Windows Vista, probably 64 bit.
http://www.hp.com/hpinfo/newsroom/press_kits/2008/siggraph/ds_elitebook8530w_mobileworkstation.pdf
^That is a link to your specific laptop if you described it properly in your question.
As far as 7 goes, you can do an install of it. If your HDD is wiped, then just insert a Windows 7 OS disk into your dvd drive and the proceed to do an install. After the OS install you will need to install drivers and additional software to unleash the laptops full potential as a computer.
I have added a video to aid your install. ( As a certified PC tech I recommend going with Windows 7 as an OS, its much better and safer than Vista)
Apr 28, 2014 | HP Elitebook 8530w Mobile Notebook
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Acer ms2253 how can I add bluetooth device
just insert the device wait for few second the message will display ' your device is ready to use' (windows vista, 7, 8, 8.1) you have to install the software cd bundled with the device for other os (XP)
Dec 12, 2013 | Computers & Internet
Perihale blootooth driver
To resolve this issue, you will need to install the device driver for your Bluetooth device. If the device came with a CD or DVD containing device drivers compatible with your version of Windows, insert that disk into the disk drive and follow the instructions to install the driver.
If your Bluetooth device did not come with a driver installation disk, you will need to go to the device manufacturer's website and download and install the latest driver for your device. To do this, go to the hardware manufacturer and search on the latest version Bluetooth driver for your device. Follow the instructions.
Windows 7 Compatibility Center
Windows Mobile Devices
If youre using a Windows Mobile device, follow the steps below to updte to the latest version of Windows Mobile Device Center 6.1
  1. Go to the Microsoft Windows Mobile Device Center 6.1 site
  2. Click Continue.
  3. If prompted, download the Windows Genuine Advantage software.
  4. Click Download, then click Run.
  5. Follow the onscreen instructions to install Microsoft Windows Mobile Device Center 6.1.
  6. Click the Start button, type device manager in the Search box, then click Device Manager.
  7. Expand Unknown Device, right click on Bluetooth Peripheral Device, then click Update driver software.
  8. Click Browse my computer for driver software, then click Let me pick from a list of device drivers on my computer.
  9. Select Bluetooth radio from the list. Under Company name choose Microsoft Corporation, then under Drivers, choose the latest version of Windows Mobile-Based Device Support.
  10. Click Next. If any warnings should appear, click Ignore, then when prompted, click Finish.
  11. Restart your computer.
Nov 09, 2013 | Lenovo Computers & Internet
Windows 7 driver for Targus ACB10US1
your driver can be downloaded by using this pro tool: Driver Update Software for XP Vista 7 8. Have a nice day
Mike
Feb 02, 2012 | Targus USB Bluetooth Adapter (ACB10US1)...
Icannot load the driver for Targus acp50us. i am running Windows 7
Do you have the 32-bit version of Windows 7 or the 64-bit version? To identify your version, click Start > Control Panel > System and Security > System. On the line that gives the OS version, if you see x64, then you have the 64-bit OS. If you do not see these extra characters, then you have the 32-bit version.
I suspect you have the x64 version of Windows 7. Targus does not have drivers for Windows 7 x64 for the ACP50US. Targus only supports the ACP45 and the ACP51 docks under the 64-bit OS.
If you have the 32-bit version of Windows 7, download the driver from http://www.targus.com/us/download.aspx?regionid=&sku=acp50us&PageName=&productCategoryId= . This is the Vista (and XP) driver. You may need to use the compatibility mode to get it to work. Right click on the executable file and choose Properties. In the Compatibility tab, choose "Run this program in the compatibility mode". Select Vista or XP in the drop down menu. Then right click on the installer again and choose Run as Administrator.
I hope this helps and I wish that I had better news for you.
Aug 18, 2011 | Targus ACP50US Docking Station
I have ask you already how to install the dual boot os(Windows xp and Windows 7 ), but i don't complete yet .Can you explain to me again step_by_step in great detail ? because when i install windows xp...
Hello, this is how I dual boot my laptop with windows xp and windows 7
1. Backup all you important files, use an external hard-disk if possible
2. Make sure you have two drives or partitions: usually drive C and D
3. Insert your xp cd, do a quick format of drive C and install
4. Boot into windows xp and format format drive D if necessary
5. Insert your windows 7 DVD and follow the prompts. When it asks you to upgrade or new install, choose new installation
6. When you are asked to choose a location choose drive D
7. Complete your windows 7 installation
8. Thats it, you can now install drivers and programs
When installation is complete you will see both os options: windows 7 and previous version of windows (i.e xp)
I have done this numerous times without the need for any other step or software. The only rule is to is to install xp first, then windows 7.
All the best
Jul 11, 2011 | Computers & Internet
Hi! im using windows 7 starter, can i used vista as my new os?
ye you can, it mean you must downgrade your pc, use vista cd to install it, but you may lost your data at drive C: you must back up your drive c: data before install vista
i hope this helpful
thank you for using fixya
Jan 30, 2011 | Computers & Internet
When i try to install language disk i am getting
Well if it works in XP and Vista then it is safe to say it isn't compatible with W7.
Remember, Windows 7 is not going to be released for another 2+ months.
I have found a large number of programs that just don't work with W7.
Your best bet is to check on Rosetta Stone's website to find out if they list W7 as a supported OS.
Aug 23, 2009 | Rosetta Stone Spanish Level 1-2-3 Full...
Targus (ACB10US) Bluetooth Wireless Adapter Logo
837 people viewed this question
Top Targus Computers & Internet Experts
J John
Dudeman321
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
