Question about Optiquest Computers & Internet
My power supply board is out on my Q7 monitor
My power supply board is out on my Q7 monito. Can I get a new one? Usually the capcitors are blown, but this one seems fine as far as the caps go.,
  • 319 Answers
Www.badcaps.net/forum/printthread.php?t=8430
Posted on Aug 02, 2010
Where can i locate the part number 4F0907279 for Q7 2006 model
Hello Enoch,
The on board power supply control unit J519 is
installed in the cockpit at the front left on the
control unit holder adjacent the steering column.
The on board power supply control unit 2 is, as shown in
the illustration, located below the right-hand front
More info and component diagrams here:
http://www.volkspage.net/technik/ssp/ssp/SSP_364.pdf ONBOARD POWER SUPPLY CONTROL MODULE AUDI A6 Q7 S6 C6 4F0907279
Jul 19, 2016 | 2006 Audi Q7
Monitor does not show images when computer is turned on until computer is re started sometimes several times, and/or several keys on keyboard are hit.While screen is black a ticking sound is...
Likely a bad power supply board, and that is almost ALWAYS a bad capacitor on the board. They cost under a dollar to purchase a replacement.
Before you fire the computer up next, try running your hair-dryer (yes, your hair-dryer!) and blowing hot air into the innards of the monitor.
If it starts then with no problem, you have "aced" what it needs for a proper repair: a new capacitor on the power supply board, and you can Google for the parts and the instructions.
Mar 07, 2015 | Computers & Internet
LG LCD Monitoer
Check the power supply section first, hopefully it will not be bad lamp assemblies.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 31, 2010 | LG 22" FLATRON LCD Monitor
I replaced the 4 capcitors on the panel and the TV
Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Put the old IP board back.Tries it again should work,if u didn't not burn anything in the Tuner signal board. Keep me in touch how it turn out!
Mar 05, 2010 | Samsung LN-S4051D 40 in. LCD Television
My rca r52wh73 wont turn on the power supply fuse was blown i replaced it and it blew right away. what do i need now and where can i find it? Thanks
You got a bad capcitor then on the power supply. You need to change out the bad capcitor so the fuse will not blow. I would recommend just buying a new power supply to save face as with anything eletronics just reparing one thing as you did brings out new issues.
Remember before touching anything eletrical I advice you if you do not know what your doing leave it to the experts who do thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 22, 2009 | RCA R52WH73 Projection Television
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
No picture on monitor
The Q7 has a tendency to burn up transistors and a high voltage capacitor on the one half of the inverter board which is part of the power board.
I have repaired 1/2 dozen of these with that problem.
Only way to tell for sure would be to open it up and look at it.
If you can do that and send me a picture to bammbamm@ptd.net, I may be able to confirm this.
The other possible problem could be a bad bulb, but since it is fairly new ? that is probably not the issue.
Fran
Jul 20, 2009 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
Black screen on monitor when pc is switched on
Does anything come up on the monitor or is it just black always
Oct 31, 2008 | Computers & Internet
Power supply pings distributions planar d6015tm
The information comes on the same manual of the planar monitor d5015TM (see as medical monitor)
Sep 12, 2007 | Planar VitalScreen D6015TM (White) 15 in....
Computers & Internet Logo
216 people viewed this question
Top Optiquest Computers & Internet Experts
Alun Cox
Vladimir Frolov
Tom Chichester
Are you an Optiquest Computer and Internet Expert? Answer questions, earn points and help others
