Question about Epson WorkForce 600 All-In-One InkJet Printer
Epson workforce 610 prints croocked
The paper input is fine, but the text comes out slightly tilted from the right side
    President:
  • 2,571 Answers
I would try holding the printer upside down and gently tapping.
There maybe something stuck in the paper in slot
Posted on Aug 02, 2010
  • Kimberly
    Kimberly Jan 08, 2017
    Roy, thank you so much! Epson never offered that as an option. Only a service center or buy a new printer, I knew it had to be simpler than that! You're the best! I think it was a push pin that fell in.
Correct setting for Epson Workforce 7520 printing on gloss paper
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Why is my printer in error state
Can you Clarify which type of error are you facing ?
Sep 21, 2014 | Epson Workforce 610 All In One Inkpr...
Ink smudge on right side of paper
Chances are high that the process of clearing the jam has resulted in ink being released from the cleaning/resting pad area based over on the right hand side (where the printhead sits when not in use).
This waste ink has probable come into contact with the rollers and other parts over on the right edge of the paper.
You'll probably see this ink slowly fade out and disappear over time. If it doesn't however there's something effectively feeding things so check the resting pad for a loose tube, overflow, puddles, etc...
If there's anything like that, report back (preferably with images).
Jul 21, 2013 | Epson Office Equipment & Supplies
I have a Epson Work Force 610 series printer that had a printer jam, how can I reset it?
There may be a scrap of paper still jamming the printer. It needs another look
Mar 24, 2013 | Epson Office Equipment & Supplies
Epson workforce 610 printing improperly
have the printer being discussed in this thread.... the Epson WorkForce 610. I just encountered the same issue, many lines were missing from the page that I wanted to print. Ink levels were fine, but every time I try to print the same thing, the same lines were missing. I read through the solutions mentioned above and I decided to see what the printer had in its maintenance toolbox on the printer itself.
Here's a solution that worked for me!
1. Go to "Setup"
2. Under Setup, select "Maintenance"
3. Select "Head Cleaning"
The printer does the head cleaning automatically. Print another page, all of the lines should show up!
Simple, no need to buy another printer or clean the ribbon...
May 01, 2012 | Epson WorkForce 600 All-In-One InkJet...
Why would paper be jamming or getting stuck on right side with black ink every time?
The rollers that advance the paper could have been messed up by the key, therefore crinkling paper and not advancing in proper timing with the ink. It also could have busted of the plastic gears in modern day printers.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Apr 24, 2012 | Epson Workforce 610 All-In-One InkJet...
Epson workfroce 610 prints crooked
then you have to adjust the paper, it might be that the printer pulls one side of the paper in first making it look tilted.
Aug 02, 2010 | Epson WorkForce 600 All-In-One InkJet...
Keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
Epson WorkForce 600 All-In-One InkJet Printer Logo
261 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
