My Johnson and Starley air flow heater is not working all the electrics are ok when started the solenoid on the Honeywell v8600c 1020 2 activated but no gas is supplied to the burners. The pilot light is working and after turning the gas off and on the pilot restarts and stays on constantly
  • 813 Answers
Hi friend
here is link for u
http://www.fixya.com/support/honeywell
Posted on Apr 25, 2008
Johnson and starley j32 pilot light on but burner not lighting
Check you have power going to the gas valve .
Feb 10, 2013 | Heating & Cooling
Heater and blower wont work and fuses are ok
will it blow air on any setting besides defrost
Dec 12, 2012 | Cars & Trucks
Heater not working
Check all fuses. Check that you are getting air flow with the fan and that it increases as you select higher settings. Do you get warm air flow when on the passive setting and you are are on the move i.e. no fan assist but air being pushed through by the motion of the vehicle. Also check the general coolant level in the car, low coolant could mean that the heat core is being deprived of coolant flow. Next check the solenoid valves with their electrical connections on the pipes to the heater core.. I can't remember if the Jeep has an independent electrical circulation pump for the heater circuit but this is the last on the list of checks
Apr 29, 2010 | 2005 Jeep Liberty
My Frigidaire stacked unit FEX831CS0 is operating ok except it doe not get as hot as it used to and will not dry the clothes. I did replace the high limit t/stat as I found it would not reset after...
The question is .. is it drying? .. if it is drying then previous to the high limit tripping you had an air flow problem creating the abnormal heat in the dryer which you took as normal .. suprise part is that if it is drying then the heat you feel now is the correct heat for that unit.
Slippy
Apr 18, 2010 | Frigidaire FEX831CS Top Load Stacked...
Pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Feb 22, 2010 | Heating & Cooling
I have a johnson & starley 25-30 modairflow
I have resently had the same problem.
called british gas to inspect the system and they found that the flue had corroded at the vent and become detached allowing corbon monoxide fumes to enter the roof space and filter down the heater causing it to cut out.
advise you to stop using heater imidiately and call for assistance befor you are all gassed.
Nov 25, 2009 | Water Heaters
Honeywell s861ou 3009 intermittent pilot module, i just installed this control on my furnace. I have one wire left from my old johnson control. this wire either goes to the draft fan or the burnham logic...
What is the wire on the old control.....what terminal is it on??....When replacing old controls the new ones often have different terminals and sometimes incorporate some terminal internally etc....the Wiring Diagram included should be followed exact....if it's working fineit's likely ok....if you have any doubt have it looked at by an expert
Oct 21, 2009 | Honeywell Electronic Programmable...
Heater chamber gets warm to touch but never gets up to temp I unhooked the copper line at the pot, turned on the heater and no k1 came out-pump wasn't activated. Flow from tank is ok-screen is clean-float...
you are describing a vented kerosene heater could be a monitor or a toyotomi. unit goes through a 300 sec purge cycle before the igniter heats up and starts the kerosene. after the purge cycle the solenoid pump is supposed to start pumping kero into the pot. if the pump is not working check for a pulsating voltage at the pump. if there is no voltage there then the pump or pump relay is shot.
Oct 16, 2009 | Heating & Cooling
Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Oct 18, 2008 | Honeywell HE220A1019 Whole House...
Heating & Cooling Logo
280 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
