Question about Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA)
The controller will not turn on. Green light on back comes on but when we turn on the unit, the fan starts briefly and then the power cuts off.
  • Compaq Master
  • 5,660 Answers
Bad Power Supply. Weak Voltage power rail.
Not enough power to turn the Processor on, and keep it on.
1) ALL those LED lights together, use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is. (Older Processors use less Wattage)
The Compaq Presario SR1810NX desktop computer, comes with an AMD Sempron 3200+, processor.
(Uses the Socket 939 processor socket)
[Maximum operating capability is a 1.8GigaHertz frequency rate.
1.8GHz
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
Frequency Rate is correct computer speak for 'Speed'
The AMD Sempron 3200+ processor, can operate at a maximum frequency rate of 1.8 Billion Cycles per Second ]
HP Support >Compaq Presario SR1810NX desktop computer > Product Information > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00609384&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=1841795&lang=en
The AMD Sempron 3200+, can use up to 62 Watts,
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors#.22Palermo.22_.28Socket_939.2C_E3_.26_E6.2C_90_nm.29
(Palermo Core)
When you press the plastic Power On button, you are contacting a Power On switch inside it.
(Typical ATX Power On switch,
http://www.directron.com/atxswitch.html )
When an ATX power supply is plugged into power, there is a 5 Volt Standby power, present inside the power supply.
Pressing the momentary contact power on switch, closes a circuit that directs the 5 Volt Standby power to 'excite' the power supply, and turn it on.
The first chip to receive power is the BIOS chip.
[Chip and Chipset are slang terms for I.C.
Integrated Circuit.
BIOS stands for Basic Input/Output System]
BIOS,
http://en.wikipedia.org/wiki/BIOS ]
BIOS looks to see what devices are installed, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(Windows XP is one example of an O/S. Operating System)
The LED lights receive power, so do the fans, and the Harddrive. When it's time for the Processor to kick on, there isn't enough power, and the Power Supply 'falls to it's knees'.
Replace the Power Supply.
It's just one of the basic ATX power supply's that are readily available in a multitude of places.
The Wattage is 300 Watts.
The ATX form factor for this power supply, (Size and shape), is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
Power cables needed:
(Continued in a Comment)
Posted on Aug 03, 2010
  • joecoolvette
    joecoolvette Aug 03, 2010
    Power cables needed, (cont.)
    A) 20-pin ATX main power cable
    http://www.playtool.com/pages/psuconnect...
    B) 4-pin ATX +12 Volt power cable, (Also known as P4, or P4 ATX 12V),
    [This can also be seen by looking at the motherboard.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    Scroll down towards the bottom of the page, for the motherboard illustration.
    The 20-pin ATX main power cable connector, on the motherboard, is shown as - ATX1
    To the right of the ram memory slots.
    The 4-pin ATX +12 Volt power cable connector, on the motherboard, is shown as - JPW1
    To the left bottom corner of the Processor socket ]
    C) Comes with an IDE (PATA) harddrive, and CD burner/DVD player optical drive.
    You need (1) standard 4-pin Peripheral power cable for the Harddrive,
    and,
    (1) standard 4-pin Peripheral power cable for that optical drive.
    (Or two for two optical drives)
    (Also called a Molex connector for that power cable. The first company to make that connector, had the name stick. Just like Crescent wrench for an adjustable open-end wrench)
    You may need an additional standard 4-pin Peripheral power cable, to connect computer case fans.
    You can obtain a Power Supply with more Wattage, and not hurt your computer.
    A computer ONLY uses the power it needs, and no more.
    More wattage will also be less strain on the Power Supply.
    This is an example of a power supply that is compatible,
    http://www.tigerdirect.com/applications/...
    Just an example.
    If you find a compatible Power Supply on the internet, and want to know if it will work, just state the URL of the link in a Comment.
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
Have sound no picture?
if the fan is cutting off and ON there is a problem with your power supply unit.
and this may also affect your other systems on the unit
Jul 30, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
KDS50A2000 Green light comes on briefly followed by red blinking light. 4 on then pause, etc. etc. Problem???
I tried this solution last night. had a similar issue. opened up the back panel and cleaned the fan. just for the fun of it, i tried to turn the tv on and presto. it works fine now and i probably saved a bundle. thanks!!!
Jan 25, 2010 | Sony KDS-50A2000 50" HDTV
Lights go dim
If you're running the car under a heavy load, lights will dim briefly (ie. you turn the ac on full)
With the engine running, the leads on the battery should read 13-14V
Aug 26, 2009 | Honda Accord Cars & Trucks
Came home today and the AC will not come back on. The out side unit is working, but the blower inside will not come on. Also the light on the control board will not light up at all. Does anyone hav
turn off power to indoor unit feel the fan motor if hot and turns rough bad if hot and turns smoth then most likley capacitor if cold check 5 amp fuse on the board jump red stat wire to green if no fan relay bad if fan stat bad hope this helps
Jun 03, 2009 | Goodman CLJ30AR32 Air Conditioner
I have a Sony kdf50we655 and replaced the burned out lamp. When I turned on the unit the light turned green and the fan starts up briefly and than everything turns off. The light turns red and blinks...
MAKE SURE YOU HAVE THE LAMP COVER ON CORRECT NOT TO TIGHT AND THAT BOTH SCREWS ARE SCREWED IN THE SAME AMOUNT TRY TO REPLACE THE COVER AND THE PANNEL AND TURN BACK ON
Mar 05, 2009 | Televison & Video
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Sound no picture?
I have no solution for this problem and I'm not sure I can fix it without taking it to a repair shop. The replies I got yesterday did not help.
Audiovox FPE3000 turned off sponataneously and will not turn back on
I would suggest getting a schematic of the set and using a multimeter looking at the power supply test points to determine what is happening exactly with the power supply.
Sep 08, 2007 | Audiovox FPE3000 30 in. HD-Ready LCD...
Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA) Logo
134 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
