I HAVE A MEMOREX VCR MVD4544. HOW DO I HOOK UP TO CABLE. THE CABLE WIRES FROM THE TV ARE NOT THE SAME.
    President:
  • 1,285 Answers
You need an adapter this will allow you to bridge both the vcr and tv together...you can go to best buy or radio shack...(if you have a cell w/ camera take a picture of back of both the TV an VCR) show it to the salesperson which will better the chances of getting the best and correct connectors for you........
Posted on Aug 08, 2010
The audio output level is too low. How do i increase it? I have to turn the volume up on the TV almost maximum to hear a "normal" level of volume.
my experience says that the VCR/DVD recorder does NOT has a volume setting inside. Cables may be bad or connected to wrong input but most likely, the TV has a setting for the volume for any source and that is probably set to mid-range like on a PC sound control panel. Go the audio setup on the TV and see if you can adjust the level for each input.
Mar 03, 2014 | Memorex MVD4544 DVD Recorder/VCR
Hook up Memorex MVD4544 DVD/VCR combo
ok on the back of the dvd player look for the yellow red and white plugs you should have gotten a cable with yellow white and red plugs match the colors from the dvd player to the colors on the back of the tv labeled VIDEO 1 then plug the power in and tune the tv to video 1
Mar 27, 2009 | Televison & Video
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Mar 09, 2008 | Memorex MVD4543A
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
