Question about Fuji FinePix 6900 Zoom Digital Camera
Starting the camera
When I switch on the camera the lens does not move out. There is power and it sounds as if the motor runs for a very short ime when I switch off.
  • 2,326 Answers
It looks like there might be a gear or motor not working properly inside the mechanism that moves the lens in and out.
If the camera is less than a year old, still under manufacturers warranty. Contact the manufacturer help line or support to find you an authorized service center.
Posted on Apr 25, 2008
  • Jaime Hernandez Apr 25, 2008
    I would also suggest to try removing the batteries to allow the camera's circuit to reset.
Canon powershot only boots in playback mode
You could try to help the lens coming out if you hear the motor trying to. Or hold the camera with the lens downwards to let gravity help as well. Hope that will help. Or the lens mechanism will be faulty and the whole lens needs to be replaced. But such a repair might not be worth it because of the costs and the value of the camera.
Jan 04, 2014 | Cameras
My 18-55mm lens won't auto focus...it works in manual my 55-200mm works fine on my D3000
-You must use a lens with internal auto-focus motor such as AF-S Nikkor, or 3rd party with built-in motor
-Is the switch`s been moved to A/M??
-The battery must have enough power to run the auto-focus motor inside the lens
Dec 25, 2010 | Nikon D3000 Digital Camera
Not closing lens
the lens uses a very small power drive motor to run 3 cogs that open the lens when this motor burns out (common) it fails to close or if a short accures from the unit to feed power to the lens motor again these are expensive repairs and in most cases the unit is binned and replaced
hope this helps you decide what to do
Nov 28, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Zoom lenses is extended but wont go back in
Switch on and PRESS the "wide angle" selector switch. (in camera mode)
Now the lens should move partially back in.
If it does not move inwards at all and you do not hear a whirring noise, then the activator motor is defect.(or the lens assy is out of alignment). (or a foreign object has entered the gearing, and stalling the motor)
If you do hear the motor running, then a gear might be stripped.
All these faults do require to take the camera apart.
Mar 08, 2009 | Fuji FinePix F650 Digital Camera
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Lenc cover will not open
Jun 12, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera lens
Apr 29, 2007 | Canon PowerShot A510 Digital Camera
Canon Ixus 40
Apr 27, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
My Camera has E18 Problem
May 07, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Fuji FinePix 6900 Zoom Digital Camera Logo
48 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
