Question about Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum
I have an electrlux pront stick vacume which no longer hlds a charge Is it true that there is a recall of the battery can I get a new battery since my husband the enginneer has diagnosed the problem as the battery
  • 34 Answers
Hmm..aug 02 2010...you probably resolved this..if not...http://www.cpsc.gov/cpscpub/prerel/prhtml09/09169.html also check the out put of the transformer...it should put out 15 volts...NOT 23 volts like mine. Saw the transformer on e-bay...http://cgi.ebay.com/NEW-15V-200mA-0-2A-AC-DC-Power-ac-adapter-Power-supply-/290372975461?pt=LH_DefaultDomain_0&hash=item439b93fb65
Posted on Nov 06, 2010
WILL NO CHARGE
The battery is probably no longer rechargeable due to age or to the number of times it has been recharged. If the battery can not be replaced, then the entire vacuum needs to be replaced with a new one.
Aug 02, 2015 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Hoover linx
How old is your battery? and did you keep it on charge when it was not in use?
Most rechargeable batteries require a spindown, where as you completely discharge the battery before recharging it again.
I know you aren't wanting to hear this but in all probability that battery is spent and will need to be reconditioned at a battery place, however, it will cost almost as much as a new one it would be your call.
if you have a ohm/volt meter it might be possible to look at the charger and get a volt/amp reading and then test it see if it is putting out the proper voltage it could be putting out a trickle charge and it would take forever to charge it.
there is one other situation to look at and if the beater brush or motor is causing a resistance it will pull a battery down quick.
I do not own this vaccum so I can only guess as to the possibilities.
Jul 02, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Filter queen power nozzle recall
you mus call them, and explain your sense, and they will accept your comments, and proceed according your will. Do it, Do not waste your time.
God bless you
Jul 23, 2012 | Filter Queen Majestic Canister Vacuum
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
It a rechargeale. It will not charge. is there any way to dismantle it and replace the rechargeable batteries. ? There does not appearto be any screws to separate the two halves of the body. maybe teh
What model...lots of recalled vacuums out there under recall for batteries. Can you solder ? The new batteries WILL have to be soldered. Can you get someone to read voltage of the piece you plug into the wall ?
Nov 06, 2010 | Vacuums
Brand new : battery charges to 60 minutes ( 8 hours)and by the next day is completely discharged.
It sounds like the battery has a faulty cell in the battery that never lets it hold a full charge or lets it bleed off. I would take it back and exchange it.
Could you provide a model number?? There may be some settings on the vacume that are continuing to use power even though it is not in use.
Thanks
Apr 11, 2010 | Vacuums
Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum Logo
234 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
