Question about GE WDSR2080D Top Load Washer
Will not start washing process.
Water continually fills machine and runs out the overflow without filling and washing cycle starting. Is there something that closes or a switch the stops the water and starts the wash cycle.
    Scholar:
  • 32 Answers
Potential problems:
1. Your vacuum tube has simply come off. 2. There is a hole in your vacuum tube, 3. Or you have a bad pressure switch.
To check,
1. Pop the top open on the unit and raise it up (for specifically how to do this, I'll need need the make and model number). You may need to disconnect wires from lid switch, noting where they go to put them back. 2. Locate a clear rubber-like tube come from under the control panel and going down the the bottom of the tub where it is connected to a small nipple. If it is not connected there, reconnect making sure it fits snug. You're problem is solved. 3. If it is connected, disconnect it and gently pull the end of the tube to you. Inspect if for holes or cracks or cuts. If it looks good, put the end of the tube (you may want to clean it if it's dirty) and blow air in it, keeping the pressure up and listen for a click under the console panel. Try again. If you hear the click, listen for air escaping from tube, maybe a pin hole or more. 4. If you do not hear the click when air pressure is applied, you have a bad pressure switch and it must be replaced, assuming the tube is actually connected to the pressure switch under the control panel. 5. Replace tube onto nipple near the bottom of the tub and replace the top. Reconnect lid switch. 6. Take control panel off and insure vacuum tube is connected to pressure switch. If it is, remove tube and blow pressure directly into pressure switch. If you hear no click, the pressure switch is bad.
To help you further or help you find the part, I will need the make and model number.
Good luck, this problem is more simple than it sounds.
G
Posted on Aug 02, 2010
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Dec 30, 2012 | Whirlpool Washing Machines
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
Model# 110 20902990 kenmore washing machine over flows
hi thanks for the question you could have a water valve problem how do you shut the water off by unplugging power cord or shutting off water supply if its unplugging the power cord you have a problem with water control switch or lint is caught in small plastic tube that goes to the water level switch check that could be no parts needed thanks the appliance doc
Sep 27, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
May 20, 2008 | Maytag Performa PAV2200
GE WDSR2080D Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
