Question about Phoenix Gold XS2300 Car Audio Amplifier
How many watts and what is cost - Phoenix Gold XS2300 Car Audio Amplifier
  • 1,498 Answers
Hey there newton,
Looks to be just over 300Watts. MSRP is $220.00 but they can be had for $100.00 to $150.00
Click here for a review.
Best regards
Mike
Posted on Aug 02, 2010
What do i have to know about watts in order to work out each appliances power usage aday
Add up all the wattages of the appliances you are using when they come on and go off including lights. fridges. freezers, fans , stoves, tools and every thing. add them all up and you will get thousands of watts called kilo watts . see how many you use per hour and you will get a kilowatt/hr usage rate. Find out the power cost per kilowatt/hr and multiply the usage by the cost and you have your answer. Or you can get a wireless transmitter that is clamped around the input line to your premises and it transmits to a receiver to inside your house (mine sits on the fridge) and it tells you the cost as everything is running . press the mode button and you get progressive cost and other modes are there as well. It is great because if I forget and leave the pool running I can see at a glance that something drawing a lot of power is running so I can check it out and turn it off. Ask you power provider about it or a good electrical shop.
Oct 07, 2013 | Computers & Internet
I have a 2800 watt and it is not louder than my 600 watt. What's my problem and how can I fix it. Thank you.
What are the exact model numbers of those amps? More than likely your 2.8K Watt amp is a complete lie, very few amps can deliver that power, if you paid under $1000 for it it's probably not likely to ever do that output, also some amps are rated at higher input voltages like 19 volts or more to achieve there advertised output but even then most will only do a fraction of what they claim. At 12volts and making those claims you'll find that Boss is a prime example so is the low end Lanzar along with many others out for sale now a days. A 2800 watt MAX amp rating is really a 150 watt x 2 output and that will be at 2 ohms, I'm not sure how it all started but way back when (back in the late 80's early 90's) there were only amps that had real power ratings and they were 25watts x 2 up to 200 watts x2 and the 25 watt amps were louder than most of these 1000watt amps you see now. A true 200 watt x 2 amp bridged in mono back then would deliver 800Watts into 4 ohms 1600 watts into 2 ohms and cost about a dollar a watt. The 25 watt x 2 amps I had would put out 400 watts in mono at 1 ohm. So you see power ratings now are just not even anything you can use unless the amp is certified to be compliant with the new car stereo rating system. Even then I cannot guarantee which amp will be louder or sound better without actually connecting it up and hearing it myself. That's how car stereo shopping used to be, you listened to the amps all side by side and realized that size, cost and power ratings make no difference until you hear the amps, then size & cost are considered. Power ratings are then forgotten all together.
Aug 19, 2013 | Car Audio & Video
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
Can I replace the 3 40 watts bulbs that came with my Hampton Bay Hawkins 44" ceiling fan with 3 60 watt bulbs?
You would be better off getting 3 40watt daylight bulbs.. extreamly bright low cost and wont cause any harm to your fan.. hope this helps :)
Oct 21, 2011 | Dryers
WHAT IS THE DIFFERENCE BETWEEN LAN(WORKGROUP) AND NCOMPUTING. ADVANTAGES AND DISADVANTAGES.
Not sure what you mean by LAN workgroup. If you're referring to traditional Local Area Networked PCs and sharing files on a server, the NComputing solution is very different. Imagine taking a standard LAN with 20 PCs, each costing at least $500 (usually much more), and having them access a network. That cost would run you $500 * 20 or $10,000. That's just for the hardware, not any of the soft dollar costs. Additionally each PC uses a minimum of 100 Watts of Power, more common these days is 250 Watts.
Now take the NComputing solution. Start by replacing ALL 20 PCs with a $150 L230 or a $200 L300 device, which only consumes 5 Watts of power. Purchase one server, say $2,000. Load up NComputing's vSpace on the server and connect all of the L devices through the network. Every user still gets their own desktop, access to the network and other peripherals. And the I.T. department now has ONE Desktop OS touch points, not 20 as they did before. Thus the NComputing solution can reduce support costs, consume less CapEx and OpEx budget while delivering desktop sessions to each user. In this example the cost would be $2,000 + (20 * $150) = $5,000.
Aug 13, 2011 | NComputing L230 Network Terminal
I just purchased a lasko model 5805 ceramic heater. What's the cost to operate.
look for the power rating of your heater (usually it is in Watts (W) and convert it to kilo Watts (kW) unit by diving it by 1000).
kW = W / 1000.
now divide the kW by hour many hours your planning to operate your unit.
power consumption = kW/operating hours
when you get your power consumption value then multiply it with the power cost (you can find it usually in your bill).
cost to operate = power consumption x power cost.
Happy New YEAR!!!!
don't forget to rate me...
Dec 31, 2010 | Lasko Ceramic Heater
I have an overhead panel of eight 4' flourescent lights which I believe are each 40 watts. The dimmer switch that controls them all as a unit has failed. Any suggestions about where to get a replacement...
Google-search: florescent slide dimmer
You have 320 Watts, 120 volts, and the circuit uses 2.6 amps.
Volts x Amps = Watts.
1) The florescent slide dimmers seem to cost $100-120
2) If you search for florescent dimmer, the cost is lower than the slide dimmer.
Leviton sells for $50
http://www.google.com/products/catalog
Nov 05, 2010 | RTO Fluorescent Slide Dimmer Switch...
My Motor Trend Inverter 400 watt give's me a fault light upon start up. The fuse is good
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Feb 15, 2010 | TREND Motor Trend Inverter 2400 Watt ...
What amp will push 2 kicker 15inch cvr's
Hello herb31,
Kicker lists the RMS power handling range of the CVR's from 100-500 watts, with a peak power capability of 1000 watts. There are lots of monoblock amps within that range. It just depends on how loud you want them and how much you want to spend.
In the low range, an amp like the Alpine MRP-M500 will deliver 250 watts to each sub at 2 ohms. And it only costs $179. Currently, the MRP-M500 is out of stock at Crutchfield. I just bought the last one. So my 2nd recommendation would be the Sony XM-1S, which has the same power rating and according to Crutchfield is no slouch either. It's also $179. I really like the Sony, too. It has a small footprint that makes it easy to find a convenient mounting location. Both the Sony and the Alpine are CEA-2006 compliant, so you can be sure that the manufacturer provided specifications are not overrated. Assuming that your vehicle electrical system can deliver the current, both the Sony and the Alpine will deliver an honest 250 watts RMS to each of your Kickers. And 250 watts will make them kick pretty darned good.
In the medium power range, consider either the JL Audio G Series G1700 which delivers 700 watts into 2 ohms. It costs $419 at Crutchfield. Or perhaps the Kicker 08ZX750 with 750 watts at a cost of $399.
To push the CVR's really hard, close to their 500 watt RMS maximum power range, look for an amp that delivers 1000 watts. In this range, you will definitely some heavy-duty wiring, electrical system upgrades, perhaps a 2 farad capacitor, and be ready to spend at least $600 on the amp. Your best combination of power and price would be another Alpine, the PDX-1.1000M, at $799. If you buy one from Crutchfield, they will throw in a 4-gauge amp wiring kit. And if you use a "friend referral code", such as mine, which is p7sdj-hrx8q-9800g, and your order is at least $200, you'll get another $20 discount. And I get a $20 credit toward a future order.
Hope this helps. If it does, please rate as "FixYa".
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
Phoenix Gold XS2300 Car Audio Amplifier Logo
61 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
