Question about Savin 9935DP Laser Printer
Code programming My copy machine have reached limit of codes and it shows on lcd screen 49/50 and after that saying that it cennot add new used codes. How can get this thing to work thank you
    Problem Solver:
  • 11 Answers
Hi There,
The max on that model is 50. You can take out the ones that you no longer use to make more space. That is the only way.
Thanks,
Steve C.
Please rate me....Thanks.
Posted on Jan 31, 2009
My sharp MX-C311 shows maintenance required Code TA
Hi, TA code refers to maintenance all counter has reached its specified limit. This usually means all the consumable parts have reached the end of their service life. If you have a maintenance contract with a Sharp dealer then they should replace all the units that require replacing & reset the maintenance counters for you, if you don't then, if the copy quality is still ok, you should be able to continue to use the machine as normal.
Hope this helps.
Dave.
Oct 15, 2017 | Sharp Office Equipment & Supplies
User codes.
that's due to having too many users..you'll need to delete some folks to make this work...maxing out the user codes will freeze the unit..
Apr 25, 2008 | Savin 9935DP Laser Printer
See photos. Screen says SLIDE LIMIT REACHED
Not sure what you are trying to do..but the info comes up because you have added photos to a slide show and the limit you can add has been reached. NO more can be added, even if added to screen saver.
Feb 24, 2015 | Cell Phones
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
How do i program a new number on the fax machine
1. Press [Menu]. 2. Use ^ to select <TEL REGISTRATION>, then press [Start/Copy]. The LCD displays <1-TOUCH SPD DIAL>. 3. Use ^ to select <CODED SPEED DIAL>, then press [Start/Copy]. The LCD displays <*00>. 4. Use ^ to select the two-digit code (00-59) under which you want to register the number, then press [Start/Copy] twice. 5. Enter the party's number and name. 6. To assign additional coded speed dialing numbers, repeat step 4. To finish, press [stop].
Aug 16, 2010 | Canon FAX-JX200
Model 34288 robinair . Were is the weight . How do you do A filter change.
There is no Weight in the machine. Machine show Filter weight that you have been recover refrigerant from the vehicles since last filter change! After every 68KG/150LBS of refrigerant recovery you must change the Spin-no filter. The machine ( Model-34788 ) will lock-up when filter capacity reach to 68kg & you will not abel to access the machin till replace new the filter.
When the machine show the filter weight 68kg on screen just press YES key,then add the 10 Digit code of new filter ( Code is stick with evey filter). If the code is accepted then open the old filter & replace new one.Follow the on screen direction to compleat the process.
Note: Do not switch off the machine till compleat the filter change function.
Jul 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
SC546
SC541 - SC-555
These codes mean you are having a problem with your fusing unit. The section of your copy machine that has to heat up before you can make copies. It runs at a pretty high temp because it has to melt the toner and press it into the paper as the copy moves through the machine. Depending on the code, your machine is either taking too long to warm up or it is overheating.
The most common reason is a build up of hard crusty toner on the temperature sensors. This tricks the machine into not seeing your fuser warm up fast enough. Most of the time you can reset this and continue to use the machine but expect the code to come back down the road. You can also get codes if the room the copy machine is in is too cold when you start up the machine. Either a cold winter day or even a summer day in a room too cold from air conditioning.
Some machines require you to enter a service code to reset a fuser/fixing unit error. Some only require you to enter the service mode, then turn the machine off / on using the main power switch. The main power switch is the one you have to rock to the off and rock back on, not the little button you press for power to come on.
To enter the service mode press the following keys in order:
Clear modes
7
then press and hold the stop key
You will see the display screen change. At this point turn the machine off / on to reset the code.
If your machine does not have an LCD display screen you should have seen the copy quantity
display change to a flashing zero.
Some machines will need to add a step to the above instructions.
Once the LCD screen changes, select the "SP Mode" selection from the touch screen.
Enter 5810
This is the Service Program (SP) that resets Service Codes (SC-###)
You will either have to select 1 to accept or select the touch screen button to activate this SP.
After you do, turn the main power off / on to reset the code.
If you try this and the code still comes back on, you have an electrical or mechanical problem that you will need to call a service company to repair. The reason for making this code so hard to reset is a safety issue. If there is a short in your fuser unit it can cause your machine to over heat and possibly cause a fire. There are thermistors (temperature sensors) and thermostats (temperature fuses) that will keep your fuser from overheating. If either of these devices are worn out, you will not be able to reset the code and will need to have your fuser serviced.
Jun 19, 2009 | Office Equipment & Supplies
Action replay code manager
Okay follow these steps very closely
1) Open Code manager and insert your AR USB cord with the AR itself in the DS slot make sure the DS is off.
2) Turn on your DS so that on the PC screen the Code Manager is listing the Games already on the AR
3) Then when the games are on the screen decide what game you want to add codes to, Makesure there is a copy of that game in the Default code list with the cheats you already have on there if the game is not in a code list in the slot "My codelists" drag the game into a code list, What should happen is the top DS screen will say Reading, then the games master code same should be on the PC screen under the new box "Process"
4) On the code list where you have just dragged the game to the game should be in there open it up by clicking the little + next to it.
5) In that game file there should be all the cheats you have prevously added. right click on the game tile and hit add new cheat, Cheat details should appear so add a name and copy and paste the code then hit okay afterwards delete the file on the AR NDS code list and copy and paste the new one so that when it is open it will have all your old cheats and the new ones.
Hope this helps, Xamous
May 16, 2009 | Datel Action Replay for Nintendo DS
Copy limit
the only way is to goto additional functions > System Settings> dept I.D > set a user code and password, then you can set a copy limit per user id, once a copy limit is reached you have to reset it or create a new user I.D. Thats the only way, you can also get reports on how many copies each I.D has done..
Hope this helps
May 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
User Code
You may want to print this out because it is long.
Adding codes
Adding codes is really pretty simple.
First Add a System Manager code:
  • Press the 'additional functions' button to the right of the touch screen.
  • Press the 'system settings' button ON the touch screen.
  • Press the 'system manager settings' button on the touch screen.
  • Press the 'system manager' button on the touch screen and then use the touch screen to enter the system manager's name. Press 'done' when you have finished.
  • Press the 'system manager id' button on the touch screen and use the numeric keypad located to the right of the touch screen to create the id.
  • Press the 'system password' button on the touch screen and enter a numeric password for the system manager. YOU SHOULD MAKE A NOTE OF THE SYSTEM MANAGER ID AND PASSWORD, AS THIS WILL BE NEEDED TO CHANGE SETTINGSLATER.
  • Press 'next' on the touch screen.
  • Press 'email address' to add an email address for the system manager.
  • Press 'contact information' to add an extension to reach the system manager at.
  • Press 'ok' to complete the process.
  • Press 'done'.
Next add user codes:
  • Press 'system settings' button on the touch screen.
  • Press 'department id management' on the touch screen.
  • Press the 'on button' on the touch screen.
  • Press the 'store dept. id / password' button on the touch screen.
  • Press 'store' on the touch screen.
  • Press 'department id' on the touch screen and then enter a numeric code using the keypad.
  • If you want additional security you can also set up a password by pressing 'password' on the touch screen and, using the numeric keypad again, enter the password. The password can be left blank if desired.
  • Additionally you can set an impression limit for that user by pressing 'impression limit' on the touch screen.
  • Press 'ok' on the touch screen to add the user.
  • If you wish to limit impressions then you must press the 'limit impress.' Button on the touch screen.
  • If you want to add more users at this time go back to step 6.
  • Press the 'done' button.
  • Press the 'off' button at the bottom of the touch screen next to 'accept jobs with unknown id.
  • Click 'ok' to complete the process and start using the copier or go back to step 5 to add more users.
After this process users will have to enter a user id to use the machine. At the end of the copying process users should press the 'id' key located at the bottom right of the keypad to logout. The machine will automatically log users out if there has been no activity for a few minutes and this can be changed by pressing 'timer settings' in the additional functions.
While this seems like a lot it actually doesn't take very long to do. There is a far more elegant set of instructions in the 'reference guide' that came with the machine, which includes pictures, and starts on page 4-2.
Nov 07, 2007 | Canon NP 6050 Copier
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
George Mclaughlin
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
