Question about GE Refrigerators
My TFX24EF side-by-side will not make ice...i get chilled water at the door but no ice....
  • stevestrat69 Aug 02, 2010
    Yes, had a feeling the prolemwas the ice maker itself...now just have to figure the cost...lol Thanks....
  • 2,272 Answers
Check for any blockage in the lines. The simples thing to do is to remove the water inlet going to the icemaker at the valve and blowing in it to see if it is blocked with ice.
icemaker fill tube is not plugged with ice. You would do this test from in back of the refrigerator, removing the plastic tube attached to the water inlet valve and blowing into it:You should also test the valve coil for continuity:valve located in the back of the freezer by the ice maker.
And verify that the you have water pressure at the water inlet valve supply. If all that checks good, then and only then can you conclude that the icemaker itself is the problem.
The problem can be any of the following:--
1) The blocked water line. 2)The faulty water valve including the solenoid. 3)The short in wirings. 4) The faulty ice maker itself. -------------- you can get required parts from www.repairclinic.com Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 02, 2010
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Not making Ice. Appears no water entering Ice making chamber even though water is at the door.
The water valve has two coils one for chilled water at the door and the other for the ice maker. Sounds as if the ice maker coil is bad. Hope this helps you to find the problem.
Apr 30, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Can you adjust the temperature on the water dispenser?
The water for the dispenser comes from a reservoir in the fresh food section behind the crisper drawers. So the only way to make the water colder is to turn down the temperature in the fresh food side of your refrigerator. The water dispenser is designed to dispense chilled water, not ice water. hope this helps.
Jan 04, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
In door water not working
when calling for water if there is a click when depressed then the problem is the dual inlet valve.
replace this valve for the fix.
Phil
Jun 10, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Is there any water problems in burtonsville i thougt the pipe broke.
If it is like my Kenmore, the water tube connection at the lower edge of the freezer door hinge line, may have come loosened by opening and closing the door. That tube provides the water source for the in-door chilled water outlet. Just tighten the connections.
Jun 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
