Question about Sony Network Walkman NW-A3000 MP3 Player
NW-A3000 Battery replacement
How is the battery replaced on this player ?
  • 1 more comment
  • peterking May 22, 2008
    The back screw is under the rear cover Walkman badge
  • bridgeboyo Aug 08, 2008
    I've taken the battery out and disconnected the wires but I can't get the battery out of the housing. How do you do it?
  • mmr12 Dec 24, 2008
    How do you get the silver screw cover off in the first place?
    Problem Solver:
  • 5 Answers
1/ Remove the screw holding the back of the player
2/ Slide back cover off
3/ Remove 4 screws at the edges of the players chassis
4/ Remove battery and connector
Posted on Apr 26, 2008
The battery is stuck down with doublesided tape. After removing the chassis with the 4 screws you can slide a screwdriver under the battery and ease it away. To disconnect the battery just pull the 2 wires. The connector should come away with without damage. Then push in the new connector. You can attach the new battery with a litttle double sided tape if you wish. Then replace the chassis and 4 screws, refit the cover and fix it with the screw. Push on the small cover, put on some double sided tape if the old stuff has lost its stickiness.
Posted on Feb 17, 2010
Everything about replacing the battery was so hard - from the instructions being wrong ( my player had one screw to be removed, not two) through to the generally fiddly nature of the whole process.The battery was only grudgingly meant to be replaced!
Posted on Jun 23, 2009
The connector slides out towards the top of the player , view it carefully and you will see
Posted on Jun 22, 2008
Whare is the screw is it under the silver id badge
Posted on May 22, 2008
  • hi ya Jun 22, 2008
    did this went to remove the battery connector and tore all the connections out. does it slip to the side becouse i just pulled it staight up
2 Suggested Answers
SOURCE: replace battery
since posting "0744tony" I llevered out the little bage on the top/back of player, and with the tiny screw driver that came with the battery, I undid the little screw underneath, it didn't come out easily. the old battery was stuck down with double sided tape and you have to be v v careful not to tear out the minute wiring our you'll be in trouble. I did change it, charged it up and all worked OK.
Posted on Jun 23, 2008
How do I open up the nwa3000 to replace the battery
It's held on by a small screw hidden behind a small circular cover on the back of the player. Just prise this off.
Mar 09, 2010 | Sony Network Walkman NW-A3000 MP3 Player
Getting stuck on the initial, splash, load up screen
have u charged the batteries fully and try, evenif the problem persists go for a battery replacement.
Jun 03, 2009 | Sony Network Walkman NW-A3000 MP3 Player
Low Battery error message
I got mine brand new, it's never lasted more than five hours. Ripoff.
Jul 16, 2008 | Sony Network Walkman NW-A3000 MP3 Player
The battery conection to the board
The manual pretty clearly states not to replace the battery - the manufacturer usually has a way to fix any issue you are having with the player. Now that you have damaged the player yourself, your warranty is voided. sorry about your luck
Jun 21, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Replace battery
Remove the screw under the Walkman badge on the back
May 21, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Asking to press hold
Can someone please tell me how i can replace the battery on my Sony NW-A3000?
Dec 27, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Sony Network Walkman NW-A3000 MP3 Player Logo
3,449 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
