Question about Raymarine Boating
My autohelm st 50 plus do not rotate any more. It stops completely. Grasing did not help. can I use a Raymasrine automelm st 50 service kit z135 D139 to restore the rotating?
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore microwave 721.80803401 rotating table pops up and stops turning.
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Posted on Dec 21, 2008
SOURCE: My roomba 560 has brushes that spin one rotation
Here's the solution to this problem...
Remove the rollers and run the Roomba and see if the problem goes away. If so, here is the solution to the problem...
Each roller has a little yellow cap on one end. Pull this cap off (it should come off easily) and remove the crud that is wrapped around the "axle" of the rollers. The crud keeps the cap from going far enough down on the axle, essentially making the roller longer. This causes the roller to get into a bind and results in the roll-thump-roll-thump-roll problem. Once the crud is removed, replace the cap, replace the roller (notice how it drops in easier now?), and enjoy your Roomba again.
Posted on Apr 25, 2009
arpit47
  • 162 Answers
SOURCE: SMPS Fan not rotating fully
you can check that how much time you spent with the SMPS if it is more then 2-3 years then change it because it is damaged in 2-3 years and after changing then also not work then you go to mechanic and checked your motherboar
Posted on Jun 29, 2009
  • 5 Answers
SOURCE: rotary hammer won't rotate, hammers very good
If tool hammers brushes still good. Motor runs hammer action.
Take hammer/ drill switch lever off by removing small plastic plug in center with small screw driver.remove indicator handle off by removing #8 torx screw and lightly pry off. There is a pin and spring that lock tool into hammer or drill.Check for broken spring or binding spring and pin.If binding , clean and grease.
Posted on Jul 08, 2009
  • 3230 Answers
SOURCE: Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Posted on Aug 24, 2009
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Autohelm ST 50 Code Lock
Sorry to be the bearer of bad news, but your unit will have to be sent to Raymarine for this one.
The information you'll require is at the link below.
-Steve
Service and Support
Mar 09, 2012 | Boating
Just interested on ''how'' the Autohelm ST1000 Plus works! is there somewhere on the net that I can check, I just bought a boat with one one it and I know how to make it work, but I want to...
Hi!
The ST1000+ does not have an internal GPS. What it does have is an electronic compass underneath the keypad. When you order the Tillerpilot to steer to a bearing, the unit uses the electronic compass to steer using a series of corrections.
Just in case you've misplaced your Owners Manual, you can use this link to download it to your computer: http://www.raymarine.com/productdocumentfinder.aspx
Click on your language preference, then Autopilots from the drop-down menu, tillerpilots and finally ST 1000+. The pdf file for your unit is 81130_6.pdf
Hope this helps and happy boating!
Jun 14, 2011 | Raymarine St1000 Plus Tiller Pilot
Autohelm 4000 ST fails to drive
CHECK INSIDE
BELT CONDITION
RUNNER BROKEN OFF
CHECK OUTSIDE
CLUTCH LEVER PIN BROKEN ,CLUCH LEVER OUT OF POSITION
BELT TENSION ADJUSTMENT WRONG (REMOVE SMALL COVER PLATE (+- 10mm Dia)ON REAR OF BACKPLATE ,LOOSE SPECIAL NUT ADJUST WITH ALLEN ,TORQUE NUT,PUT COVER BACK
Feb 19, 2010 | Raymarine St 4000 Wheel Drive E12093
I HAVE A 1997 AUTOHELM ST4000 AUTOPILOT AND THE
GLUE THE SMALL POSTS EXACTLY IN PLACE AS THEY BROKE OFF ,DRILL A HOLE VERTICALLY THROUGH THE POSTS ,SAME SIZE AS HOLE IN THE SS WHASHER, (HOLE OF THE SCREWS)ALL THE WAY THROUGH THE BACKPLATE ,INSTALL A STAILLESS SCREW WITH HEAD ON THE REAR OF THE BACKPLATE AND NUT ON THE WASHER SIDE TRIM TO EXACT LENGHT USE LOCKTITE FOR NUT.
Jan 05, 2010 | Raymarine St 4000 Wheel Drive E12093
Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
Dec 18, 2009 | Raymarine St 4000 Wheel Drive E12093
ST4000 autohelm
The clutch lever shearpin is on the outside through the body of the clutch lever
Jul 06, 2009 | Raymarine St 4000 Wheel Drive E12093
Autohelm st50 how to calibrate??? wind instrument
I had one. Don't think you calibrate it. Reading is relative to it's mounting base. To change the direction reading, you would need to rotate the base.
Jun 10, 2009 | Boating
Boating Logo
75 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
