Question about HP Officejet J5780 All-In-One InkJet Printer
Cartiage alignment not working. put paper in document feeder,always says error . went under tools and aligned
  • 319 Answers
Omputershopper.com/printers/reviews/hp-officejet-pro-8500/.../10
Posted on Aug 02, 2010
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
How to clear the display error on konica minolta c452
Sir there is a lever in the rear of the machine when you lift the document feeder it is not jam or broke, also there is a small magnet and sensor in the front of the Doc feeder right side and the copier it self ensure the document feeder is properly aligned. Does this happen on the document feeder or on the big glass? Also mite want to have a technician run alignment & tray adjustment.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 06, 2014 | Konica Minolta Bizhub C452 Color Copier,...
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
How to set original to adf
Check the document feeder is it aligned properly. There is a small magnet and sensor magnet on the Document feeder right front sensor under the plastic that side ensure they are aligned. Does happen when you make copies?
Mar 16, 2013 | Minolta FAX2900 Plain Paper Laser
Paper jam & a 5110 error code on my 830MP
Error 5110 is a carriage lift error. The pr lift shaft is probably not rotating or the gear that drives it has broken teeth. now you mention paper jam. Ah thats it. I presume you had paper jammed in the machine and you pulled it out while it was under tension. Doing this will break not only the gear but the assy sheet feeder to. You will most probably need a new sheet feeder and the PR lift gear.
Alas you cannot fix this yourself and there is a special alignment that needs to be carried out between the gear and the sheet feeder. If they are not perfectly aligned the sheet feeder will strip its teeth from its gear and it will be scrap.
Do yourself a favour give it to Canon trained engineer and not just any old engineer. This is a specialist job i am afraid.
Good luck.
Aug 23, 2011 | Office Equipment & Supplies
Alignment issue causing copies to be cutoff
Firstly check are the left i right holder in paper tray in their position accordingly formats eg A4. Then very well clean, if necesarry replace, pick up, feed and separation rollers. Clean the other paper feed rollers on paper way.
Also check the registration roller and clutch.
If nothing of this helps, send another message, then you will get adjustment info.
Jun 15, 2010 | Canon imageRUNNER 210S Copier
Feeder problems with Pixma 9500
By having a certified technician do a cleaning on the feed rollers this should fix the problem.
Jun 04, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
HOW TO ALIGN PAGE IN THE ADF
you need to place a blank sheet on the automatic document feeder....then align the printer from the menu buttons....but tak care you have papers both in the paper tray as well as the document feeder then only it will align the cartridges.....see if it works!!!
Jun 25, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Printer cartiage error
This page may help.  One of the things it's supposed to help with is 'cartridge error'.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00094661&dlc=en&product=374581
If that doesn't help, can you provide more detail about the cartridge error message?
Dec 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
Jul 29, 2008 | Lexmark T644 Laser Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
