Question about Samsung Techsan LM1770A 17" Monitor
Screen goes black after splash screen in windows 7 but it works in safe mode
  • 319 Answers
Www.fixya.com/support/t5449111-power_supply_board
Posted on Aug 02, 2010
Acer aspire one d270 netbook how do i go in safe
Start tapping F8 before the windows 7 Splash screen goes away, that should give you access to Safe Mode.
Oct 11, 2014 | Computers & Internet
Compatible with MS Office 2013 and Windows 7
Go to safe mode and uninstall the application or restore system
Press f8 while booting up to get into safe mode...
Dec 21, 2013 | Dell E173FP 17" LCD Monitor
My 531S hangs at the dell splash screen with one short beep before loading windows vista
I would start the computer in safe mode. To do this, keep tapping on the F8 key as you start the computer. Do this as soon as you see anything on the screen. If you get the windows splash screen, you've waited too long. Once you get the white menu on a black screen, choose safe mode and let it start. The next time you do a restart, it should work. If it doesn't, then in safe mode do a system restore back to the time it worked.
Apr 06, 2012 | Dell I531S-2809 PC Desktop
I press f8 when starting but unable to get into safe mode. I have windows 7 OS on an ASUS A52F.
You have to tap F8 Repeatedly right after the initial splash screen goes away. Then it will come up with a menu for you to choose Safe Mode.
Jun 30, 2011 | ASUS A52F-XT1R 15.6" Laptop Computer PC...
Window 7 every 20 minutes hang
Many things could be causing this, the first thing I would do is boot into safe mode and see if the issue continues.
Safe Mode
Just before the Windows 7 splash screen (black with windows logo) appears, press the F8 key to enterAdvanced Boot Options.
You should now see the Advanced Boot Options screen. If not, you may have missed the short window of opportunity to press F8 in the previous step and Windows 7 is probably now continuing to boot normally assuming it's able to. If this is the case, just restart your computer and try pressing F8 again.
Here you are presented with three variations of Windows 7 Safe Mode you may enter:
  • Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Mar 15, 2011 | Toshiba Satellite L305D-S5935 15.4-Inch...
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
How do i get into safe mode on a thinkpad r50?
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Mar 10, 2010 | IBM ThinkPad R50e Notebook
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Ati Radeon 9000 video card driver
It could be related to the display resolution settings. If you can boot into "VGA mode", that should get you started.
Dec 19, 2007 | ATI RADEON 9000 Graphic Card
Samsung Techsan LM1770A 17" Monitor Logo
52 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
