Question about M-Audio Fast Track Pro External Sound System
Sound card freezes up
My problem started about 1 month ago. I have my laptop hooked up thur my mixer using the M-Audio sound card so I can play and cue up the left and right channles I'm a DJ. My problem started with the right channel it sometimes freezes up in the middle of play and nothing comes out of it but static mixed with music. Here recently in the middle of play both channels will freeze up and all you hear is a loud static sound and I have to restart the laptop. One other thing I notice is when it freezes up the levels on both channels jump up high and stay there. I don't think its the laptop because I've been using it with the same sound card I brought both at the same time almost a year age. Can you help I have to play tonight.
  • brooksl May 08, 2008
    Ok what is a enternal power supply going to do for my problem?
Buy enternal power supply for it.
9 Volts
1000mA
But mind that it should be psu with REGULATED output(steady 9Volts).
Posted on May 08, 2008
I am not getting sound thur my mixer what could be the problem.
Is there any hum sound? Are the switches set to the proper inputs-phono, line?
Feb 14, 2015 | Numark Im1 2-channel Pro Dj Mixer With...
Qfx1222 usb/hp envy computer - no sound frm mp3 music files
When you connect your laptop to the behringer mixer via USB it effectively uses the mixer as the audio interface.
You will need to hear the audio through the mixer either through headphones or external speakers.
There is no way that I am aware of that you can route all audio back through your laptop's speakers.
Mar 16, 2017 | Music
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
No sound!
Hi, I'm Azrul. Compaq presario srt1603wm uses the realtek AC'97 hardware. There are many drivers available for realtek.
Dec 21, 2008 | Compaq Audio card Sound Card
Audio Recording Problems
try using the windows sound recorder to see if that records music? if it doesnt then you need to go into your sound recording properties and change it from mic to wave
Dec 02, 2008 | E-Mu 0404 Sound Card
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
Help
you cannot get your tv to play surround sound through the speakers, but if your tv has either a scart 21 pin socket or an audio out, you can fit a scart to phono adapter and connect the phono plugs to the audio left right input on your sound system, likewise if you have audio left and right output(phono) on the tv, connect to audio in on your unit. You should have a choice of output channels on the system menu, similiar to DVD/video1/video2 or output 1 and 2 or auxilliary 1 and 2
Jun 04, 2007 | Audiovox DV1532 System
M-Audio Fast Track Pro External Sound System Logo
217 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
