I have a Onkyo TX-SR308 new and a panasonic TV new and I have 5 speakers connected to the Onkyo with woofer connected. but I get no sound out of speakers. I have hdmi cable connected between reciever and tv. Do I need audio cables connected between receiver an tv. If so what kind of cables as receiver came with no cables.
  • 6,993 Answers
yes, you need an audio cable. The cable you will be needing is called "RCA". Its a white and red (left and right audio cord) wire. You can get this cord from any electronics accessories store/shop.
Good luck.
Posted on Aug 02, 2010
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
I have an onkyo tx-sr308 and I am receiving only static or very low music on my right speaker channel. Please help
Switch to the other set of speaker outputs (move from A to B). If it continues, you have a repair issue...assuming it happens with all inputs. If it only happens with DVD, or CD, or Tuner, or whatever, but works fine with other components, it's a connection issue - unplugging and replugging, or replacing cables may correct.
If I recall correctly, that unit doesn't have a standard twist knob style balance control. If it does, turn the unit off and rotate it through it's full range several times, then recenter it and try listening to it again.
Jun 25, 2011 | Onkyo TX-SV444 Receiver
Hi! I have onkyo TX-SR308 and i surround problem.
You need to tell it you have surround speakers. Page 30.
The manual is available here...
http://www.onkyousa.com/model.cfm?m=TX-SR308&class=Receiver&p=d
Apr 28, 2010 | Onkyo HTR500 Receiver
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Set-up problem with sound and speakers
I sent this TX-SR605 system to an authorized dealer for repair. It seems like it is a very simply problem - the internal set-up mic jacket closed circuit, so the system think the set-up mic is always plugged in (even when physically unplugged it, the system still detect plugged in). And it enters the automatic speaker setup and never quit.
Now I have the receiver back home and tested it. Everything worked O.K. now. It is a pity that this new-bought equipment (just one month) need repair for just a small action of plug in a mic ( I swear I plugged it in very tenderly). It is shame for such a unreliable performance happened on brand name like ONKYO. How can you be confident for an equipment failure in one month.
Dec 25, 2007 | Onkyo TX-SR605 Receiver
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
