Question about Kitchen Ranges
Getting an oven off Auto setting
Hotpoint EW 62 cooker stuck on 'Auto',I have no users manual so how can I fix this problem / Thanks in advance
  • Anonymous Jun 07, 2008
    i have a belling format fan oven. no users manual. stucck on automatic. how do i revert to manual?
  • Anonymous Apr 10, 2009
    There must be a way of removing the flashing auto. Otherwise it can't be used. Can somebody please give me some sort of idea as to how to fix this annoying problem
Auto wont go off on belling cooker
Posted on Dec 01, 2008
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
I have a hotpoint ew 52 cooker and the grill does not work. it is part of the top oven.
You need to establish if it is the element that has failed or the control switch, usually it is the element(s)
Aug 07, 2010 | Hotpoint Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Just info plz sy36x
In your browser bar type in hotpoint user manuals
Then in the drop down list ,click on hotpoint manuals- user guides.
Then enter your model in the search box, and you can download the manual to your hard drive or send it to your printer..
Thanks.
Jan 12, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Instruction manual required
I have checked the Hotpoint website user manuals, and your model EW 84 is listed and available for download, so don't know why you could not find it.
If you still can't find it let me know.
Thanks.
Dec 27, 2008 | Hotpoint Ovens
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Thanks.
Dec 26, 2008 | Ovens
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
Hotpoint BU72 Cooker - Oven not getting to temprature
Lower oven has new element but still not reaching correct temperature.
Mar 16, 2008 | Hotpoint Kitchen Ranges
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Kitchen Ranges Logo
691 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
