Question about AKG C3000 K66 KIT Microphone
The microphone does not work or pick up sound. WHen connected to mixer no sound comes out. The cables are fine as I tried it with another microphone. It is an excellent mike and I would prefer to get it fixed then buy something else.
    Novelist:
  • 169 Answers
Does your mixer have phantom power, this is a condenser mic it needs power.
Its all in the specs on AKG website
Hope this helps
Thanks for using FixYa
Posted on Aug 03, 2010
I hear a white noise when I connect microphone with mixer (Behringer DX2000)
You posted this in questions about the Shure PG42 mic. That mic comes in two versions. There's the USB version which connects direct to a PC. Then there's the standard version which is used with a mixer. I presume you have the standard version as the Behringer doesn't have inputs for USB mics.
The standard version is a condenser mic. It needs power. The power is supplied by the mixer. It is known as phantom power because it travels up the mic cable from the mixer to the mic.
  • Make sure your mixer has phantom power switched on.
  • Use the correct mic cable: Either a 3 pin XLR to 3 pin XLR, or a 3 pin XLR to 3-pole jack (TRS). The leadis a balanced mic cable
  • Check the setting on the mic for attenuation. 0dB is no reduction in signal level. 20dB is a large reduction
  • Look at the Behringer's settings. Make sure you know what each control does and how it affects the sound. Pay particular attention to the effects send and return (FX SND RTN)
Most times there's an issue with no sound from a mic, it's usually down to a poor quality or broken cable; or no power; or the settings on the mixer.
Aug 29, 2014 | Shure PG42 Microphone
Mxl 770 won't pick up sound
Condenser microphones require Phantom Power from and external source, such as a good mixer. Make sure your mixer has it available and it is turned on. Then make sure you have a good and properly wired mic cable. If these suggestions do not help I would contact the manufaturer or retailer where the mic was purchased. Take the mic to a music store and ask yhem to hook it up to see if it will work.
Dec 03, 2013 | MXL 770 Professional Microphone
Sennheiser md 42 microphone not being picked up on camcorder help please.
This would require a special cable to work. The mic is MONOAURAL with BALANCED output and the camera is STEREO input. This means a special cable is needed and you would probably have to make it yourself as I haven't seen one on the market.Pin 2 of the XLR of the mic would go to BOTH the tip and ring of the plug into the camera. Both pins 1 and 3 of the XLR at the mic would tie to the sleeve of the plug to the camera. If you tried an XLR to 1/8 adapter, no audio would be heard other than from the buillt in mic.
Mar 08, 2013 | Sennheiser MD 42 Professional Microphone
Mixer not working with Skype
Skype allows only one audio input at the time. You can set up the input device in the skype menu.
Try connecting all microphones to the Mackie and then connect the output from it to the line in or microphone input on the PC, then choose the input you connected it to in skype.
Jan 29, 2013 | Mackie Onyx 820i FireWire Recording Mixer
How to connect it ?
Instructions
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Jun 19, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
Headphones not working, microphone is working but quiet
Right click on the volume icon and go to volume mixer. There may be a specific volume option that has been lowered. Alternatively, you can go to playback devices and check the your headset settings there.
May 17, 2012 | Televison & Video
Sometimes my AKG Perception 420 won't record properly, when played back it sounds like white noise with the faintest sound of what i'm trying to record in the background
All microphones have a signal to noise ratio. Basically defined as the level of desired sound to background noise (unwanted sound). Microphone phones also have self noise which should be considered when choosing a mic. There will be noise in every mic, some more audible than others. Condenser microphones require phantom power (48V). This can be supplied by mic prea
mps, mixers, and similar equipment. *Note that phantom power (mic pre amps) must be on or engaged, this can be specific to different types of equipment.
Troubleshooting:Has your microphone been dropped or exposed to moisture? Internal damage to your microphone will be hard to assess but this could possibly be the issue. Inspect the microphone cable, check for damages. Try using a another microphone cable-- preferably a new one. Next to check would be your mic's power supply. Make sure all connections are made properly (mic to cable to power supply). If you are using a mixer or pre amp with multiple inputs, test the mic on each input. (You should test by making recordings and comparing with each change to isolate possible causes). Also test the mixer or pre amp by slowly sweeping the input gain feature while recording an audible source such as singing into the microphone. Typically next in the audio recording chain would be your DAW (digital audio workstation) or computer, but problems with noise most likely precede this.
I could possibly provide more useful information if I know your exact setup.
Provided that you have your equipment setup properly, the microphone or mixer/preamp could possibly be damaged/malfunctioning. I suggest taking your equipment to a trusted repair shop, or if still under warranty, returning to the manufacturer for repairs or replacement.
Hope this helps
Apr 05, 2011 | AKG Perception 420 Microphone
No sound being picked up when connected, may be as I am using a xlr to usb connection and the power is coming off a laptop , how would I fix this? Thanks
The Rode NT1A requires phantom power of 24-48volts DC. The USB socket on your laptop will only supply 4.5volts.
The solution will be to buy a separate power supply or to connect it to your computer through a mixer that includes a phantom power supply option.
Feb 24, 2011 | Rode NT1A Professional Microphone
I have a superlu pra-h7a. I also have a cable that connects to the bottom via a three pronged male plug with with a female connector on the other end. i have not used this in years, and can't remember how...
You need to connect it to a mixer first and from there to an amp/speaker combo. This microphone needs phantom power and you can only get it via the mixer. Also, you can control the volume via the mixer. Depends on what kind of speaker you have (active or passive) you will need an amplifier. If you're trying to plug it into a guitar amp, it won't work without a mixer. Plug the 3-prong xlr male cable into the input of the mixer. The 3-prong female xlr end goes into the mic.
Oct 08, 2010 | Superlux PRA-H7A Professional Microphone
Microphone does not pick up any sound
Your mike requires a 48 volt phantom power supply which your preamp should be supplying. The most commonly overlooked problem is the cable. It must be wired for a balanced connection for phantom power to work correctly. 1=ground/shield, 2=hot(ve) and 3=cold(ve). None of these connections should be bridged to another and need to be kept separate to maintain a balanced connection. You will need to eliminate the preamp and mike cable as sources of the problem in order to determine if the mike is working correctly. You need to test this combination with a volt /ohm meter. If you don't know how to do this you should take it to the dealer you bought it from for testing or advice.
Oct 15, 2009 | M-Audio Luna Professional Microphone
AKG C3000 K66 KIT Microphone Logo
146 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Ben Armstrong
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
