Lanier LD135 fax error - nothing going through error results indicate no answer??? What can I check...?
  • 319 Answers
Www.articlesnatch.com/topic/bin/11
Posted on Aug 02, 2010
LANIER LD135 CODIGO DE ERROR SC990
Depends on the associate engine code. Most of the time it means that maintenance is overdue. Otherwise, it is an electronic issue.
Jun 10, 2014 | Lanier Office Equipment & Supplies
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
Scan routing
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/x22_27/x22_27en.htm
Go to the above site and download your software and a manual, the manual tells you exactly how and what to do.
May 21, 2010 | Lanier 5222/27 Laser Printer
Lanier LD135. How do I program it to print
Envelopes thru bypass only....once they are set youl need to set the bypass to envelopes at the machine either thru user tools or by pressing bypass then the # key and selecting envelope or custom size and entering the size of your envelopes.
Back at the computer go into print proprties and select paper souce bypass the printdriver will use the machine settings unless ou tell it otherwise
Feb 24, 2010 | Lanier Office Equipment & Supplies
I need to get a meter reading on a Lanier LD135/145 copier.
Hello sir; You just press "user mode' it will show up "total count"
Aug 06, 2009 | Lanier Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Change delivery server IP Address
I had this problem with an Aficio 2018D using scan router ScanRouter V2 Lite. The MFP would say it couldn't update the delivery list. Deleting/Reinstalling SW, resetting the I/O device and so on, nothing worked. At last I had to use the SP 5845 (see maintenance manual) to manually change the Delivery Server IP address, which was initially set to 127.0.0.1 and had by then been corrupted to 0.0.0.0, to 192.168.1.227 which was the IP address of the WinXP where ScanRouter was running (of course port 3870/tcp must be opened as exception in Windows Firewall). The scanner immediately "saw" the delivery list, updated by itself and, touching wood, worked like a charm ever since.
Dec 26, 2008 | Office Equipment & Supplies
Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Jul 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
66 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
