Samsung YP-K3 MP3 Player Logo
Posted on Aug 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I pulled out the usb connection from my computer on accident and I cannot get it to work anymore...i tried the reset button...tried usb connection, tried everything except opening it up...it just doesnt respond at all.
Anonymous
Level 3:
  • Master 677 Answers
  • Posted on Aug 02, 2010
Anonymous
Master
Level 3:
Answers
677
Questions
0
Helped
173278
Points
2133
Hi,what you need to do if the mp3 player is not yet damaged yet after pulling out the Usb without using the safely remove option is that you will need to uninstall the drivers or software for the mp3 player and reinstall it then connect the mp3player back . If after connecting back and it doesn't display ,that means you have damaged the mp3 layer.You will need to get a new one. Take care.
My black web silent keyboard and mouse use to work now when i try to connect the mouse just flashes, wont connect anymore.I have tried everything is there a reset button on the mouse or the keyboard
No,there is not, you might go to settings and check, If the USB receiver is bad neither keyboard or mouse will work. It would be better to replace with a better brand. reviews are not favorable.
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
My wireless mouse doesn't work anymore i try changing the battery yet it doesn't work what should i do?
I have this problem all the time.. if you already changed the battery what you need to do is remove the usb that came with it from the computer cause most likely when you changed the batteries it reset the code for your computer and mouse so, take the usb out that came with the mouse and hit the button on the mouse ... take the usb out and replug it and it should work soon as you hit the button on the mouse...
hope this helps...
2helpful
2answers
Jakks spytech watch only will work when connected to USB port of computer. If disconnected it goes blank and will not operate. When connected toi USB port the following message is the only thing...
Same problem. But I am able to set the location, time and date while usb connected. As soon as I pull it out, total failure. Even tried the RESET button on back, but nothing works.
Anybody... anybody?
2helpful
My microsoft mouse msk-1056 is not working. I accidently ttok out the usb drive and then when i put it back in it wokred for a short period of time then froze. I tried everything. How do i get it to work?
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
4helpful
Canon pixma ip1000
I try this to my customer canon printer and it is working even i used only the step one method.
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door of the printer, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
2answers
Ipod nano 2nd generation won't mount
Could be a hardware problem. Sometimes ipods will not connect to a computer even when everything else is working fine.
4answers
Setting the time on a Timex Data Link 851 Watch
You have to use the USB cable and do it through your computer. There is no way to change the time on the watch. Bad design.
Dec 31, 2007 • Watches
4helpful
7answers
Samsung stuck on hold
I'd suggest bringing it back to the store where you purchased it or phoning a samsung help line.
1helpful
2answers
Camera lens is out, but camera is off
First deconnect all batteries, usb cable anything from the camera. Leave it for about 1 hour and then without connecting batteries press and keep the the power button pressed for about 1min. Then press twice on every other button including the shuter, zoom or stuff like that. This should reset a microcontroller that remembers the last operation done. This doesn't reset the camera. After this, connect the batteries and try to power it again. IF this doesn't work. Try to push the lens back in using your fingers. Don't force them to much if they doesn't appear to go back. Use 2 fingers to press on the lens one on each side aplying equal pressure. You may hear a click noise when the lents start to go back. Again, don't force them to much. Try these at first and then if they doesn't work, please post back and specify what does the camera do. No led's no nothing or ..?
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
