Question about Savin 9935DP Laser Printer
User codes. I got a copy machine SAVIN 9935DP. Machine have a code setting. The code setting reached limit of 49/50. After that it showa a message on lcd screen that it "cannot add new user code". Please somebody help me with this problem. Without this code machine will not work. Thanks.
  • Vyacheslav Apr 25, 2008
    How I can do that?
    how can I delit users. I got this machine a week ego and don't know yet all about it.
    Thanks
    Genius:
  • 2,785 Answers
As the error is stating that your user account is almost full,plz delete the unwanted user,and in future keep minimum user.
Posted on Apr 25, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Apr 26, 2008
    please refer to the manual or visit the manufacture website
  • Muhammad shahid Mar 04, 2015
    Admin only user and OK
    Genius:
  • 3,587 Answers
That's due to having too many users..you'll need to delete some folks to make this work...maxing out the user codes will freeze the unit..
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
Savin 9940DP ''Set Key Counter''
Key counters are used when a copy machine is set up for public use where copies are charged on a per copy basis. Key counters look like small boxes that plug into the side of the machine and they have a counter on them that looks like a cars odometer. A user plugs in the key counter, makes copies and then takes the counter to a register to pay for the copies they made. Sounds like that is what you have going on.
Nov 02, 2009 | Savin Office Equipment & Supplies
SAVIN PRINTER INITIALIZATION CODES
I need to see a sample of the data file being sent to the printer. Please create a, "Print to File" and then send the file to me.
I also need to see the formatting commands that you are sending to the printer.
Don
don.farr@verizon.net
Oct 19, 2009 | Savin 9935DP Laser Printer
I have the same problem with a Ricoh aficio 700 SC495
check the door contacts and the contacts on the transfer unit these need to be clean also
Sep 17, 2009 | Savin 9935DP Laser Printer
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Functional Problem SC326-00
Hi There,
This error has to do with the laser unit. There is a special fix for it, and it needs to be done by a Ricoh Technician. The laser front right corner needs to be adjusted. For this one, you will have to place a service call.
This happened during the move.
Steve C.
Dec 06, 2008 | Savin 9935DP Laser Printer
Scanner module needed for Savin 9935DP
Hi There,
Go to this link...it is the same model, except listed as a Gestetner.
http://www.nrgcss.com/drivers/Page3.asp?Brand=gest&Vw=&Fltr=0&Ky=578808089&Usr=&Cat=3&Mdl=11&Drv=3127
Good Luck.
Steve C.
PS... Please Rate Me.
Nov 20, 2008 | Savin 9935DP Laser Printer
Code programming
Hi There,
The max on that model is 50. You can take out the ones that you no longer use to make more space. That is the only way.
Thanks,
Steve C.
Please rate me....Thanks.
Apr 25, 2008 | Savin 9935DP Laser Printer
Problems with user codes
press the [user tools\counter] key then while holding pressed the "#" key press on the touch screen [system settings] and the machine will bring back the settings to default. You can reapeat the procedure for al other settings. If you need more instructions i will send you the operating instructions by e-mail if you want.
My e-mail address is "ivicaspasovski@gmail.com"
Nov 13, 2007 | Office Equipment & Supplies
185 people viewed this question
Top Savin Office Equipment & Supplies Experts
Adorjani Laszlo
George Mclaughlin
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
