Question about Jensen Televison & Video
When i change the channels it takes 2 to 3 min for the picture to come on it only started after we got cable it is a je3208
  • Jensen Master
  • 1,230 Answers
You have a bad capacitor. A bad capacitor will show low voltage and move to a point where it may not operate this TV. This capacitor may be located near the tuner, or it may be near the flyback and always suspect those high voltage low Mf capacitors. Such as 160 volts to 200 volt at 1 Mf ,2.2Mf, and 4.7Mf. These are most certainly contributors to your problem! At its worst point the tuner may need resoldered or replaced.Hope this helps you. Thanks for asking me!
Posted on Aug 02, 2010
How do I change Channel default on start up
Use your remote. Press menu and look up initial set up or reset to factory settings.
* Note that as of Jan 2018 most cable companies do not provide analog outputs to TV sets. If your still using Channel 3 for an input to your TV then it won't work or will stop working some time this year.
* Hook up your TV using the old RCA video/audio jacks; Yellow plug is video, Red is audio right, White is audio left.
* You can also use an HDMI cable (best) for High Def picture which is all the rage for HD TV.
* You may also connect using the DVD style cable hook up which uses 4-5 separate cables (3 for colors and 2 for audio)
* Once you have some sort of video or message on the TV screen then you can proceed to setting up the cable box. Have the cable box hooked up and on for at least 15 mins. Look at the cable box display till the correct time is displayed. Power up the cable box till you see the power on indicator. Now use your TV remote to select the correct input you hooked your cables t. (probably HDMI) The display should show you your cable service. Now use the cable remote to select your channel.
* If you don't have a cable box but still have digital service (usually called basic cable - no premium) then use the analog/digital input on the TV remote and select initial set up. There should be an automatic channel search and set up to scan all the channels available on the line your connected to. This will take up to 15mins. If you know the specific channel you can cancel the scan and pick each channel for you own list. Letting the scan run may help you find other channels you are unaware of.
* Final; if your still having problems then call you TV MFR support line and they will talk you through to check your set.
* You can also check the cable company support line if the TV check out okay. The cable company may or may not be able to supply you service for really old Tube style TV sets as most if not all TV's are digital now.
Aloha, ukeboy57
May 29, 2018 | Computers & Internet
Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Oct 27, 2008 | Televison & Video
Iv tuned in a new dgital tv, but channel 1 and 2 dont tune it, programs start a 3, if u go backwards, its channel 805 i think press the remote button to analauge and u get channel 1 and 2 but not good...
If you've got a digital box from your cable provider, your tv most likely needs to be on channel 3. At that point you would use the remote that came with the digital box to change the channel. (in other words, your tv would always stay on channel 3)
Mar 09, 2011 | Televison & Video
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Dec 09, 2008 | LG 37LC7D 37 in. LCD HDTV
Legend LCD tv power issue
It's the power supply gone bad, just had the same problem. The repair guy charged $195.
Apr 19, 2008 | Televison & Video
Popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Dec 26, 2007 | Bose 3 2 1 GSX System
Pip
Take the cable wire that hooks to the IN connector on your cable box and hook it to the IN connector on a 2-way cable splitter.Get 2 more short cable wires and hook one end to the OUT connector on the splitter and the other end to the IN connector on the cable box.Take the other short wire and hook it to the other OUT connector on the splitter then hook the other end of this wire to your tv (you must have two sets of RF connectors on your tv for this to work)Or you can tap the A/V connector off your cable box hooked to a video input on your tv.
Aug 19, 2007 | RCA P52930BL 52" Rear Projection...
Picture problem when changing channels
Are you using a cable box or a satelitte reciever? If so i would suspect them first. If not, unplug the TV for 2 minutes and try again.
Feb 09, 2007 | Mitsubishi WD-62528 62 in. LCD Television
TV will not get cable channels
If you have it hooked up to a digital box, it shouldn't matter if the TV is on cable or antenna mode. The only thing that matters is that the TV is on channel 3. Channels will be changed on digital box. Some newer TV's use input 1 or 2 or AUX for it to work. If I were you i would hook everything up and start playing with the channels going up and down until you get a picture.
Dec 28, 2006 | Orion1934 19" TV
Televison & Video Logo
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
