Question about Brother DCP 130C All-In-One InkJet Printer
Paper jam wont go away after checking - Brother DCP 130C All-In-One InkJet Printer
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
If there is a paper jam there must be somewhere a piece stuck. Take out the toner and check in the toner part if a piece is left then open up the back door and check there too. Also make sure that from the bottom tray that the printer feeds there is no paper stuck there. Then close the printer and turn it on holding down the go button for 3 seconds it will reset the printer.
Good luck!!
Please post if the problem was still not solved.
Posted on Aug 02, 2010
Printer has new ink & wont print also has paper jam
The paper jam is the problem.
Clear the paper jam, recycle (Turn off, then turn on the printer) , and the other problems will go away by themselves.
Oct 25, 2015 | Office Equipment & Supplies
Rx585 paper jam
Turn off the printer and turn it back on. It just needs restarting.
David
Jun 18, 2013 | Epson RX585/RX595/RX610
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
Hi I had a paper jam in my MFC 8820d - I removed the cover and removed the paper but I still get a Paper Jam error msg. I powered down the machine and turned back on - still same error msg. I have removed...
This can sometimes be related to paper dust interfering with a sensor. A burst of canned air can fix the problem. Just pull out the toner, open all of the covers and spray air into all the little crevices. You might want to do this outside, in case toner is loose in ther, so as not to make a mess.
Sep 02, 2009 | Brother MFC 8820D All-In-One Laser Printer
Dispalays Reads paper jam and wont disappear
Unplug the power cord then put it back up. This restarts the printer again in case the on/off button does not work to turn the printer off. Then check if there's a paper jam. To do this open the scanner lid and also the glass lid, just the way you access the inks when replacing them. Check to see if there's any paper stuck underneath the inks by the printer rollers along the paper path.
Apr 06, 2009 | Lexmark X4650 InkJet Printer
Paper jam
Very frustrating ... checked all over for remaining jams - but the message "paper jam" just won't go away after clearing a paper jam. Eventually, it goes away but no way to predict how long it will take!
Feb 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Brother DCP 130C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
