Give me an example of solving problem by Block-model Approach
    Sergeant:
  • 191 Answers
What is meant by systematic and objective approach
the words are the clue to the answer
systematic approach is to do every thing systematically
step one on to step 2 on to set 3 etc
example is -- know what is needed , find supplier, place order , pay for the order, receive the order , check the order, place on display, sell , receive payment, bank funds , reorder item
objective approach is to decide on what is required and planning to reach that objective
example -- need goods for sale, how to get the goods , how to pay for the goods , how to improve on the process
IN business it will work like this
example a CEO of a company wants to reduce the injury rate of the employees
he sets a policy that has KPI's and bench marks to achieve the end result of reduced injuries( objective )
The managers have to implement that policy and have to plan each step( systematic) of the operation to eliminate risks that cause the injuries and in the end achieves the objective of the CEO
Sep 04, 2016 | Computers & Internet
Block inappropriate email chrome hotmail
can be done with filters depending on how you read your emails if you use hotmail.com it's in options and settings for spam or filters
this link has a simple approach
May 15, 2012 | hotmail.com
I have a front loading washing machine with many symbols and no mnaul. Is there a key you can give me to tell me what the symbols mean? Thanks
Go to back of washing machine and look for label with model number and serial number.
Take a photo so the numbers are easy to read.
Then search for example: Maytag RG3455 .pdf
Be sure to include .pdf in search parameter.
Another approach is to contact repairclinic.com and see if they have schematic or manual.
Also re-post question at fixya clearly stating your brand and model number to see if someone has a link or has a manual.
Better results at fixya might be available when offering $3-5, since somebody has done work to find and post manuals for your benefit.
Mar 24, 2011 | Whirlpool Washing Machine Knob - 3362624
LOCATION ON ENGINE NUMBER OF KIA SPORTAGE 2005 MODEL
Find the engine identification tag. Attached at the factory, this tag is normally found on the engine block around the coil bolts. The top line of the tag identifies engine size and model year.
Search the block for the engine block casting number. The numbers are raised, not stamped into the block and consist of seven numeric digits. The digits can be located on either side of the block. The seven-digit number may be followed with a dash and further numbers. These are change codes and are not normally necessary to identify the engine.
EX.:
Locate the casting date is located on the block. It is in standard date coding, 2.25.93, for example and may be located on either side of the block, but is commonly located on the driver's side of the block, above the freeze plugs. The example 2.25.93 decodes as February 25, 1993. The casting date may be near the casting clock, which designates the hour the block was cast. Magnum engines were manufactured from 1993 to 2002, so verifying the date code helps identify the engine.
Jan 15, 2011 | 2005 Kia Sportage
When i turn on unit the logo appears then the screen goes blank
The easiest way is to reset or else reinstall the software application. This should solve your problem. This is a general way of fixing these items but different made may vary and I am posting this solution as a general rule for fixing it. You may also need to connect it to a pc, download the software from garmin etc and upload it on the unit. Note that if it is also a good practice to back up the software if possible. Hope this helps, and if you have any question please feel free to ask. NOTE : This is a general rule of approach to fix this GPS and different made may vary, for example, some models have a storage card which can be removed and others do not.
Dec 30, 2010 | Garmin nuvi 205W GPS Receiver
Our Hello our dishwasher does not fill the container with dishes, the heating works fine because of that we smell burned food rest. What do you thinck is defect? I thicnk it's the wtaer dispencer. can...
SInce you have not mentioned the details of the fault in the dishwasher I shall give you a link which might be of help with detials to approach the fault.
so click on the link and check with your make/model. Dishwasher
Dec 22, 2010 | Dishwashers
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
What is an ER Model? Give an example of an ER Model using block diagrams.
> ER ?
Are you asking about "DR", namely creating an independent copy of your computer-centre, that is a "backup-site", as part of your "D(isaster) R(ecovery)" Business Continuation Plan?
Aug 29, 2010 | Computers & Internet
I forgot my security code
just try to recall it or u will approach the company's service center of the dealer don't try to give fake password because it will create more risk to unlock the phone.
May 01, 2009 | Nokia 3120 Cellular Phone
Computers & Internet Logo
349 people viewed this question
Alun Cox
David Payne
David Payne
