Question about Sony Playstation 3 (PS3) Console
I have plugged my playstation back into my television after using it on another with a hdmi cable and it is not shopwing on any of the av channels. what shall i do?
    Novelist:
  • 105 Answers
Hello, the problem is that maybe your friend did set the video output on hdmi, which maybe is not supported by your tv. To setup a new video output from scratch, press and hold the power button on the PS3 until you hear a double beep. Now you'll be able to choose a new video source. If you need more info please ask. Good luck, Peter
Posted on Aug 02, 2010
I have the system hooked up and it comes on but not o the tv screen do i need the hd cable to make it work it is a flat screen tv please let me know what to do i have playstation 2 already hooked up and...
Are you using the AV connector cable? If so look on your tv for an av channel. Best thing to do though is Try using a HDMI cable. Most tv's recognise when a HDMI cable is plugged in and the tv switches automatically to the HD channel.
Hope this helps.
LJ.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I'm teying to connect my JVC tv to PS3 and tv says have no signal on screen.Help?
Hi giosal2000
Firstly what cable are u using avi or hdmi...You will need to set the tv channel to hdmi if you use that cable or av 1 or av 2 if you use the red,yellow,white cable...Please get back to me with what cable you are using so i can help you further thanks nikki
Please rate my answer.Thanks for using FixYa.
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
Weve got a toshiba tv model 289s4A & want to plug our ps2 into it, cant find how go get the av channel on the tv. We have connected the av cables but when you change channels on the tv, theres no...
If you have the remote, look for the source button. It should allow you to toggle the settings.
Otherwise they are usually after channel 2 as in Hdmi, Av1, AV2 etc..
Good luck
Dec 09, 2010 | Toshiba Televison & Video
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    When i plug my hdmi cable into the back of my PS3, it says no input on my TV ?
    you need to connect both the yellow red white cable and the hdmi cable into your ps3 and go the yellow red white av channel
    go to the ps3 settings and change the video settings (ithink) to hdmi and also change the sound to hdmi
    the screen will go blank and then the tv should change to the hdmi av channel if not change to it and accept the changes
    Dec 13, 2009 | Sony Playstation 3 (PS3) Console
    PS3 doesn't work with tv anymore
    did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
    Thx
    Aug 01, 2009 | Sony Playstation 3 (PS3) Console
    Stuck on hdmi
    Just plug the AV cable in as normal. The PS3 auto-detects the AV cable. Turn your PS3 on first, then your TV. Change the channel on your TV to your AV channel (YPBPR) and it should come on fine.
    Feb 21, 2009 | Sony PlayStation® 3 (60 GB) Console
    PS3 HDMI & AV outputs not working?!?!?!?
    change the sound output to HDMI? does the sound work on just like a normal tv channel?
    Sep 03, 2008 | Sony Playstation 3 (PS3) Console
    PS3 no longer communicating with TV
    All: Try this -
    P
    erform the following steps to reset the Video Output Settings.
    1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
    NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
    As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
    If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
    With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
    If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
    1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
    3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
    4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
    5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
    6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
    7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
    Dec 16, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    47 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
